| WD400YR Hercules http://forum.hddguru.com/viewtopic.php?f=11&t=25595 |
Page 1 of 1 |
| Author: | toasta [ March 20th, 2013, 11:12 ] |
| Post subject: | WD400YR Hercules |
Does anyone here remember which pin to cut on Marvell SATA bridge chip so that the PC3K can access ROM/RAM directly. As of now the PC3K will only access ROM if the PCB is attached to a working drive. It will not access ROM even in safe mode. And I remember from years ago when these drives came out that a pin needed to be cut to do this. Thanks |
