 Post subject: Seagate 7200,10 , please
PostPosted: April 11th, 2013, 23:11
T>((VALID Cert Disk Code Detected - Revision # .03M
T>/1
1>N1
Can't execute AT overlay calls when cert code is present
smartres.c - ovl L1 failed
need help, thanks.
 Post subject: Re: Seagate 7200,10 , please
PostPosted: April 12th, 2013, 4:15
Spildit wrote:
I think that a firmware overlay is damaged or missing.
What happened to the drive ? Did someone tryed to selfscan it ?
Do you need the data from the drive ?
i too think that Ata and try to Upload but failed.
How to fix, i not need data. please.
PostPosted: April 16th, 2013, 13:58
Dont do Ctrl+R before Smart clear .
Restart drive and the /1 then 1>N1 .
PostPosted: April 17th, 2013, 4:14
Reset
4096k x 16 DRAM
NIGHTHAWKPLUS - 1_Disk S-16 07-11-07_15:56
Buzz HM SFI
(P)SATA Reset
Failed sys sect. write! Nwt Er 7b RdWr 17404.01.0002
Failed sys sect. write! Nwt Er 7b RdWr 17404.01.006d
T>/1
1>N1
1>
After update smart : Power off and power on
4096k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
Initializing SMART SectorsFailed sys sect. write! Nwt Er 7b RdWr 17404.01.0001
(H)SATA Reset
T>
PostPosted: April 17th, 2013, 14:55
Do a F> repair that will fix the issue .
PostPosted: April 17th, 2013, 22:24
I am using HD Doctor Seagate.
why, after run F-repair, drive starts running seftcan( Begin test 02).
What to do after completing seftcan. ( update ATA and what to do anymore)
I did as instructed but not always successful
