 Post subject: ST3160815AS, bad "S"
PostPosted: April 15th, 2013, 21:47
why, after sefttest the hard drive was bad "S" from about 50% onwards
 Post subject: Re: ST3160815AS, bad "S"
PostPosted: April 16th, 2013, 17:31
hi everyone. can any body help me in seagate self test ?
hopefully waiting :)
PostPosted: April 16th, 2013, 17:52
thanks spildit i will try then tell u what happend :)
PostPosted: April 16th, 2013, 22:10
Spildit wrote:
Maybe something went wrong with selfscan.
Looks like a translator issue.
At what level did self scan finished ?
Did you get any errors ? Did you save the log at the end of the ss ?
Can you post a log of the drive with the response of some diag commands like "." ";" etc ?
Reset
1024k x 16 DRAM
NHAWK - 1_Disk S-42 03-27-07_13:01
HM SFI
(P)SATA Reset
Pgm=00 Trk=FFFFF(13706:00[14669]).1(1).077(FFF) Zn=0 Err=00 ErCt=0000 Hlth=200C CHlth=0000 Ready LBA=03DA8DAA
Age=50 Type=03 MxCyl=23633 MxHd=1 MxSct=964 BSz=002M TCode=FF01FE02 ThermFlts=0000
/T
T>
:5000000C03000001 AX`5RA229MY' "000000000000"1369A-13817
SRAM Ovly = Diag
((Reset
1024k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
(H)SATA Reset
((VALID Cert Disk Code Detected - Revision # .082
T>y
PhysCyl GrayCyl
1st Sys Cyl 0001369A 00014615
1st 0 Offset Cyl 000136A4 0001461F
1st App Code Cyl 000136B0 0001462B
2nd App Code Cyl 000136B2 0001462D
2nd 0 Offset Cyl 000136BE 00014639
3rd App Code Cyl 000136CA 00014645
4th App Code Cyl 000136CC 00014647
1st Adaptive Cyl 000136CE 00014649
1st UsrDfect Cyl 000136D4 0001464F
1st Alt Pool Cyl 000136E0 0001465B
1st CertCode Cyl 000136FE 00014679
1st IntfCode Cyl 00013702 0001467D
1st Intf Sys Cyl 00013706 00014681
1st Cert Log Cyl 00013740 000146BB
1st Decay Cyl 000137FC 00014777
1st SPLASH Cyl 00013816 00014791
Last System Cyl 00013817 00014792
Copy PhysCyl StartSec length Name
0000 00136A4 0000 0001 BootAdaptives
0001 00136A4 00D5 0001 BootAdaptives
0002 00136A4 01AA 0001 BootAdaptives
0003 00136BE 0000 0001 BootAdaptives
0004 00136BE 00D5 0001 BootAdaptives
0005 00136BE 01AA 0001 BootAdaptives
0000 00136A4 0001 0003 RsvTrackDefLst
0001 00136A4 00D6 0003 RsvTrackDefLst
0002 00136A4 01AB 0003 RsvTrackDefLst
0003 00136BE 0001 0003 RsvTrackDefLst
0004 00136BE 00D6 0003 RsvTrackDefLst
0005 00136BE 01AB 0003 RsvTrackDefLst
0000 00136B0 0000 0238 AppCode
0001 00136B2 001E 0238 AppCode
0002 00136CA 0000 0238 AppCode
0003 00136CC 001E 0238 AppCode
0000 00136CE 0000 001C DriveAdaps
0001 00136D0 0028 001C DriveAdaps
0002 00136D2 0050 001C DriveAdaps
0000 00136CE 001C 0010 MediaZonTbl
0001 00136D0 0044 0010 MediaZonTbl
0002 00136D2 006C 0010 MediaZonTbl
0000 00136CE 002C 0004 ACFCTbl
0001 00136D0 0054 0004 ACFCTbl
0002 00136D2 007C 0004 ACFCTbl
0000 00136CE 0030 0004 BackUpACFCTbl
0001 00136D0 0058 0004 BackUpACFCTbl
0002 00136D2 0080 0004 BackUpACFCTbl
0000 00136CE 0034 0018 AltLst
0001 00136D0 005C 0018 AltLst
0002 00136D2 0084 0018 AltLst
0000 00136CE 004C 0024 DosTbl
0001 00136D0 0074 0024 DosTbl
0002 00136D2 009C 0024 DosTbl
0000 00136D4 0000 00B4 UsrSlipKBALst
0001 00136D6 0000 00B4 UsrSlipKBALst
0002 00136D8 0000 00B4 UsrSlipKBALst
0000 00136DA 0000 00B4 UsrSlipDftLst
0001 00136DC 0000 00B4 UsrSlipDftLst
0002 00136DE 0000 00B4 UsrSlipDftLst
T>/2
2>x
Head 00
Zone 00: 00018 - 02387 1430 (0596) 900.000
Zone 01: 02388 - 04337 1393 (0571) 878.225
Zone 02: 04338 - 05B37 0 (0000) 861.290
Zone 03: 05B38 - 087A7 0 (0000) 829.492
Zone 04: 087A8 - 0ACF7 0 (0000) 800.460
Zone 05: 0ACF8 - 0D997 1210 (04BA) 764.516
Zone 06: 0D998 - 0FF17 1155 (0483) 733.064
Zone 07: 0FF18 - 12C77 1100 (044C) 691.935
Zone 08: 12C78 - 14B97 1045 (0415) 662.462
Zone 09: 14B98 - 16FC7 990 (03DE) 625.512
Zone 0A: 16FC8 - 18EB7 935 (03A7) 593.548
Zone 0B: 18EB8 - 1B227 880 (0370) 554.516
Zone 0C: 1B228 - 1CC07 825 (0339) 527.046
Zone 0D: 1CC08 - 1EA07 770 (0302) 491.474
Zone 0E: 1EA08 - 1FB47 733 (02DD) 470.322
Zone 0F: 1FB48 - 20AA7 696 (02B8) 450.000
Head 01
Zone 00: 00018 - 028B7 1485 (05CD) 934.838
Zone 01: 028B8 - 05CB7 1430 (0596) 900.000
Zone 02: 05CB8 - 07D03 1393 (0571) 878.225
Zone 03: 07D04 - 09E1F 1351 (0547) 854.377
Zone 04: 09E20 - 0BF6F 1320 (0528) 829.492
Zone 05: 0BF70 - 0E503 1265 (04F1) 800.460
Zone 06: 0E504 - 1107B 1210 (04BA) 765.725
Zone 07: 1107C - 13E97 1144 (0478) 725.806
Zone 08: 13E98 - 1642B 1100 (044C) 691.935
Zone 09: 1642C - 18207 1045 (0415) 662.462
Zone 0A: 18208 - 1A663 990 (03DE) 627.096
Zone 0B: 1A664 - 1C717 935 (03A7) 593.841
Zone 0C: 1C718 - 1EB73 880 (0370) 554.516
Zone 0D: 1EB74 - 2053F 825 (0339) 527.046
Zone 0E: 20540 - 221E3 770 (0302) 493.548
Zone 0F: 221E4 - 23633 722 (02D2) 466.451
Reserve: 1369A - 13817 640 (0280) 524.653
Total KBAs = 12B9FBA8
2>
I run the F-repair seftcan.
PostPosted: April 17th, 2013, 5:39
i need fix bad "s"
I tested N10,,22, but it still fails.
Everything works fine except that errors
I will try to run N2,AA,22.
thanks you.
