| ST3160815AS, bad "S" http://forum.hddguru.com/viewtopic.php?f=11&t=25787 |
Page 1 of 1 |
| Author: | y0k090 [ April 15th, 2013, 21:47 ] |
| Post subject: | ST3160815AS, bad "S" |
why, after sefttest the hard drive was bad "S" from about 50% onwards |
| Author: | muhammad shafiq za [ April 16th, 2013, 17:31 ] |
| Post subject: | Re: ST3160815AS, bad "S" |
hi everyone. can any body help me in seagate self test ? hopefully waiting |
| Author: | muhammad shafiq za [ April 16th, 2013, 17:52 ] |
thanks spildit i will try then tell u what happend |
| Author: | y0k090 [ April 16th, 2013, 22:10 ] |
Spildit wrote: Maybe something went wrong with selfscan. Looks like a translator issue. At what level did self scan finished ? Did you get any errors ? Did you save the log at the end of the ss ? Can you post a log of the drive with the response of some diag commands like "." ";" etc ? Quote: Reset 1024k x 16 DRAM NHAWK - 1_Disk S-42 03-27-07_13:01 HM SFI ! (P)SATA Reset Pgm=00 Trk=FFFFF(13706:00[14669]).1(1).077(FFF) Zn=0 Err=00 ErCt=0000 Hlth=200C CHlth=0000 Ready LBA=03DA8DAA Age=50 Type=03 MxCyl=23633 MxHd=1 MxSct=964 BSz=002M TCode=FF01FE02 ThermFlts=0000 ( Quote: /T T> :5000000C03000001 AX`5RA229MY' "000000000000"1369A-13817 SRAM Ovly = Diag ((Reset 1024k x 16 DRAM NHAWK - 1_Disk S-42 03-27-07_13:01 Buzz HM SFI ! (P)SATA Reset (H)SATA Reset ((VALID Cert Disk Code Detected - Revision # .082 T>y PhysCyl GrayCyl 1st Sys Cyl 0001369A 00014615 1st 0 Offset Cyl 000136A4 0001461F 1st App Code Cyl 000136B0 0001462B 2nd App Code Cyl 000136B2 0001462D 2nd 0 Offset Cyl 000136BE 00014639 3rd App Code Cyl 000136CA 00014645 4th App Code Cyl 000136CC 00014647 1st Adaptive Cyl 000136CE 00014649 1st UsrDfect Cyl 000136D4 0001464F 1st Alt Pool Cyl 000136E0 0001465B 1st CertCode Cyl 000136FE 00014679 1st IntfCode Cyl 00013702 0001467D 1st Intf Sys Cyl 00013706 00014681 1st Cert Log Cyl 00013740 000146BB 1st Decay Cyl 000137FC 00014777 1st SPLASH Cyl 00013816 00014791 Last System Cyl 00013817 00014792 Copy PhysCyl StartSec length Name 0000 00136A4 0000 0001 BootAdaptives 0001 00136A4 00D5 0001 BootAdaptives 0002 00136A4 01AA 0001 BootAdaptives 0003 00136BE 0000 0001 BootAdaptives 0004 00136BE 00D5 0001 BootAdaptives 0005 00136BE 01AA 0001 BootAdaptives 0000 00136A4 0001 0003 RsvTrackDefLst 0001 00136A4 00D6 0003 RsvTrackDefLst 0002 00136A4 01AB 0003 RsvTrackDefLst 0003 00136BE 0001 0003 RsvTrackDefLst 0004 00136BE 00D6 0003 RsvTrackDefLst 0005 00136BE 01AB 0003 RsvTrackDefLst 0000 00136B0 0000 0238 AppCode 0001 00136B2 001E 0238 AppCode 0002 00136CA 0000 0238 AppCode 0003 00136CC 001E 0238 AppCode 0000 00136CE 0000 001C DriveAdaps 0001 00136D0 0028 001C DriveAdaps 0002 00136D2 0050 001C DriveAdaps 0000 00136CE 001C 0010 MediaZonTbl 0001 00136D0 0044 0010 MediaZonTbl 0002 00136D2 006C 0010 MediaZonTbl 0000 00136CE 002C 0004 ACFCTbl 0001 00136D0 0054 0004 ACFCTbl 0002 00136D2 007C 0004 ACFCTbl 0000 00136CE 0030 0004 BackUpACFCTbl 0001 00136D0 0058 0004 BackUpACFCTbl 0002 00136D2 0080 0004 BackUpACFCTbl 0000 00136CE 0034 0018 AltLst 0001 00136D0 005C 0018 AltLst 0002 00136D2 0084 0018 AltLst 0000 00136CE 004C 0024 DosTbl 0001 00136D0 0074 0024 DosTbl 0002 00136D2 009C 0024 DosTbl 0000 00136D4 0000 00B4 UsrSlipKBALst 0001 00136D6 0000 00B4 UsrSlipKBALst 0002 00136D8 0000 00B4 UsrSlipKBALst 0000 00136DA 0000 00B4 UsrSlipDftLst 0001 00136DC 0000 00B4 UsrSlipDftLst 0002 00136DE 0000 00B4 UsrSlipDftLst T>/2 2>x Head 00 Zone 00: 00018 - 02387 1430 (0596) 900.000 Zone 01: 02388 - 04337 1393 (0571) 878.225 Zone 02: 04338 - 05B37 0 (0000) 861.290 Zone 03: 05B38 - 087A7 0 (0000) 829.492 Zone 04: 087A8 - 0ACF7 0 (0000) 800.460 Zone 05: 0ACF8 - 0D997 1210 (04BA) 764.516 Zone 06: 0D998 - 0FF17 1155 (0483) 733.064 Zone 07: 0FF18 - 12C77 1100 (044C) 691.935 Zone 08: 12C78 - 14B97 1045 (0415) 662.462 Zone 09: 14B98 - 16FC7 990 (03DE) 625.512 Zone 0A: 16FC8 - 18EB7 935 (03A7) 593.548 Zone 0B: 18EB8 - 1B227 880 (0370) 554.516 Zone 0C: 1B228 - 1CC07 825 (0339) 527.046 Zone 0D: 1CC08 - 1EA07 770 (0302) 491.474 Zone 0E: 1EA08 - 1FB47 733 (02DD) 470.322 Zone 0F: 1FB48 - 20AA7 696 (02B8) 450.000 Head 01 Zone 00: 00018 - 028B7 1485 (05CD) 934.838 Zone 01: 028B8 - 05CB7 1430 (0596) 900.000 Zone 02: 05CB8 - 07D03 1393 (0571) 878.225 Zone 03: 07D04 - 09E1F 1351 (0547) 854.377 Zone 04: 09E20 - 0BF6F 1320 (0528) 829.492 Zone 05: 0BF70 - 0E503 1265 (04F1) 800.460 Zone 06: 0E504 - 1107B 1210 (04BA) 765.725 Zone 07: 1107C - 13E97 1144 (0478) 725.806 Zone 08: 13E98 - 1642B 1100 (044C) 691.935 Zone 09: 1642C - 18207 1045 (0415) 662.462 Zone 0A: 18208 - 1A663 990 (03DE) 627.096 Zone 0B: 1A664 - 1C717 935 (03A7) 593.841 Zone 0C: 1C718 - 1EB73 880 (0370) 554.516 Zone 0D: 1EB74 - 2053F 825 (0339) 527.046 Zone 0E: 20540 - 221E3 770 (0302) 493.548 Zone 0F: 221E4 - 23633 722 (02D2) 466.451 Reserve: 1369A - 13817 640 (0280) 524.653 Total KBAs = 12B9FBA8 2> I run the F-repair seftcan. |
| Author: | y0k090 [ April 17th, 2013, 5:39 ] |
i need fix bad "s" I tested N10,,22, but it still fails. Everything works fine except that errors I will try to run N2,AA,22. thanks you. |
