 Post subject: Error DiskAccess ReadSector EC=43
PostPosted: May 3rd, 2013, 6:04
Reset
4096k x 16 DRAM
NIGHTHAWKPLUS - 1_Disk S-18 07-26-07_11:51
HM SFI
(P)SATA Reset
Failed sys sect. write! Nwt Er 65 RdWr 16bc6.00.0002
Read Ver Retrys
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 16bc8.00.014f
DiskAccess ReadSector EC=43 at ffffffff.00.0005
DiskAccess ReadSector EC=43 at ffffffff.00.006d
Failed sys sect. write! Nwt Er 65 RdWr 16bc6.00.006d
Read Ver Retrys
Read Ver Retrys
DiskAccess ReadSector EC=47 at ffffffff.00.006d
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
T>((VALID Cert Disk Code Detected - Revision # .03B
T>T4
Begin Test 04
Cert Table loaded
ASCII logging on
ASCII logging off
ASCII logging on
Kick Off Test
Testing head 0...
DAC value = FEA9
Biasing with current 0025mA
DAC value = FD9A
Biasing with current 0050mA
DAC value = FC8B
Biasing with current 0075mA
DAC value = FB78
Biasing with current 0100mA
DAC value = FA6E
Biasing with current 0125mA
DAC value = F963
Biasing with current 0150mA
DAC value = F851
Biasing with current 0175mA
DAC value = F747
Biasing with current 0200mA
DAC value = FEA7
Passed Max OD Bias Current = 0200mA. Limit = 0100mA
Buzz HM SFI
Testing head 1...
DAC value = FECB
DAC value = FDC2
DAC value = FCB2
DAC value = FB9F
DAC value = FA97
DAC value = F987
DAC value = F87D
DAC value = F768
DAC value = FED0
Buzz HM SFI
!!! Adaptives corrupt !!!
ASCII logging off
Test=50, Feature=0, cumhlth=20dc, curhlth=208c
AbEnd Test 04
Code - CF Track 00053(00051).0.000 Sns 000 Rty 027F.FF.80FF Rtf 1800 LBA 0D05CFD5
T>
How to fix.
I tried to run but defective sefttest.
need to change the swap head
thanks!
