| Error DiskAccess ReadSector EC=43 http://forum.hddguru.com/viewtopic.php?f=11&t=25916 |
Page 1 of 1 |
| Author: | y0k090 [ May 3rd, 2013, 6:04 ] |
| Post subject: | Error DiskAccess ReadSector EC=43 |
Quote: Reset 4096k x 16 DRAM NIGHTHAWKPLUS - 1_Disk S-18 07-26-07_11:51 HM SFI ! (P)SATA Reset Failed sys sect. write! Nwt Er 65 RdWr 16bc6.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys Read Ver Retrys Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Failure! Failed sys sect. write! Nwt Er 00 RdWr 16bc8.00.014f DiskAccess ReadSector EC=43 at ffffffff.00.0005 DiskAccess ReadSector EC=43 at ffffffff.00.006d Failed sys sect. write! Nwt Er 65 RdWr 16bc6.00.006d DiskAccess ReadSector EC=43 at ffffffff.00.006d Read Ver Retrys DiskAccess ReadSector EC=43 at ffffffff.00.006d Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.006d Read Ver Retrys DiskAccess ReadSector EC=43 at ffffffff.00.006d Read Ver Retrys DiskAccess ReadSector EC=43 at ffffffff.00.006d Read Ver Failure! Failed sys sect. write! Nwt Er 00 RdWr 16bc8.00.014f ( T>((VALID Cert Disk Code Detected - Revision # .03B T>T4 Begin Test 04 Cert Table loaded ASCII logging on ASCII logging off ASCII logging on Kick Off Test Testing head 0... DAC value = FEA9 Biasing with current 0025mA DAC value = FD9A Biasing with current 0050mA DAC value = FC8B Biasing with current 0075mA DAC value = FB78 Biasing with current 0100mA DAC value = FA6E Biasing with current 0125mA DAC value = F963 Biasing with current 0150mA DAC value = F851 Biasing with current 0175mA DAC value = F747 Biasing with current 0200mA DAC value = FEA7 Passed Max OD Bias Current = 0200mA. Limit = 0100mA Buzz HM SFI ! Testing head 1... DAC value = FECB Biasing with current 0025mA DAC value = FDC2 Biasing with current 0050mA DAC value = FCB2 Biasing with current 0075mA DAC value = FB9F Biasing with current 0100mA DAC value = FA97 Biasing with current 0125mA DAC value = F987 Biasing with current 0150mA DAC value = F87D Biasing with current 0175mA DAC value = F768 Biasing with current 0200mA DAC value = FED0 Passed Max OD Bias Current = 0200mA. Limit = 0100mA Buzz HM SFI ! !!! Adaptives corrupt !!! ASCII logging off !!! Adaptives corrupt !!! Test=50, Feature=0, cumhlth=20dc, curhlth=208c AbEnd Test 04 Code - CF Track 00053(00051).0.000 Sns 000 Rty 027F.FF.80FF Rtf 1800 LBA 0D05CFD5 T> How to fix. I tried to run but defective sefttest. need to change the swap head thanks! |
