 Post subject: how to remove zero track bad for seagate 340014a alpine.??
PostPosted: May 5th, 2013, 14:32
hellow experts
i try victoria mhdd and other i think is this service track problem any suggestion me plz
 Post subject: Re: how to remove zero track bad for seagate 340014a alpine.
PostPosted: May 5th, 2013, 14:40
Have you got a (legitimate) PC-3000? If not, then you are posting in the wrong place...
Why exactly do you think that? Please list all of the tests that you have done, the results of those tests, and your interpretation of those results. Without clear and unambiguous explanations from you, we don't know why you think this is an SA problem...
PostPosted: May 5th, 2013, 14:54
my drive show green and red blocks from starting sectors and i am gone to check the drive is victoria so drive is now hang and show bsy bsy
PostPosted: May 5th, 2013, 15:14
@moiz h/d,
I was writing some more info, but I'll stop here since you are getting lots of advice from Spildit and I don't want you to be overloaded with questions / advice. Good luck!
PostPosted: May 5th, 2013, 15:37
this is the terminal log data
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Spin Ready
8.16 03-09-04 14:03
(P)PATA Reset
Master
T>N1
Missing Critical Parameter
Code - FB Track 0EB9C.0.007 Sns 006 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
T>Interface task reset
Spin Ready
8.16 03-09-04 14:03
(P)PATA Reset
Master
(S)PATA Reset
CE Log EC=0 Rtype=9 OV=0 STStatus0
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
AT Er 00 Nwt Er 1b RdWr 004b.00.0000
ATA St d0 Er 00 Op 42 e, 000dc00,0001 0000 0000
Niwot: 0000dc00 16 0000dc00.0.000 0000 8000 0200 0100
CE Log EC=1b Rtype=0 OV=0 STStatus0
Niwot: 0000dca7 16 0000dca7.0.000 0000 8000 02a7 0100
AT Er 00 Nwt Er 1c RdWr 004b.00.0000
Niwot: 0000dca8 16 0000dca8.0.000 0000 8000 02a8 0100
CE Log EC=1c Rtype=0 OV=0 STStatus0
AT Er 00 Nwt Er 47 RdWr 004b.00.0000
ATA St d0 Er 10 Op 42 e, 000dc00,0001 7eff 0000
Niwot: 0000dc00 1a 0000dc00.0.000 0000 8000 0600 033e
(P)(H)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
Spin Ready
8.16 03-09-04 14:03
(P)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
T>
T>l1
Command Inactive - No VALID Cert Code Detected
T>L1
T>f
T>
T>
T>
T>
T>/f
T>/1
1>/2
2>/3
3>N1
3>f
ALPINE - 1_Disk 8.16 03-09-04 14:03
Built for ALPINE,GRAND2,Diamondback,TI1761 PreAmp,STL6 Andante PreAmp,InternalSpin,GC110,SVC123AC,OneToOne,2Disk,LowDelta,220 Servos,7200RPM,8Pole,NonModGray,100MHz,Code DRAM,Early Exit,Stall Converter,RwFeat=0200,SeaDex,MDW
:5000001820040000 AX`3JX9KTLV "000000000000"0EB70-0EBEF
SRAM Ovly = Diag
Pgm=00 Trk=14FC6(15050).0(0).11A(39A) Zn=E Err=00 ErCt=0000 Hlth=0018 CHlth=0000 Ntrdy LBA=0000DC3E
[[[(S)PATA Reset
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
8.16 03-09-04 14:03
(P)PATA Reset
Master
(S)PATA Reset
Master
PostPosted: May 5th, 2013, 16:32
i dont need data i just want to repair my hdd
did u tell me seagate comand for working seagate hdd plzz like head deppop and head cut and other
PostPosted: May 6th, 2013, 1:56
spildit did u tell me what is vendor track and app code ??? my pc3k menu is shown writing service track so i presss the writing st show me more option app code and like vendor code and etc ??
Users browsing this forum: No registered users and 17 guests
