| how to remove zero track bad for seagate 340014a alpine.?? http://forum.hddguru.com/viewtopic.php?f=11&t=25940 |
Page 1 of 1 |
| Author: | moiz h/d [ May 5th, 2013, 14:32 ] |
| Post subject: | how to remove zero track bad for seagate 340014a alpine.?? |
hellow experts how to remove zero track bad for seagate 340014a alpine.?? i try victoria mhdd and other i think is this service track problem any suggestion me plz |
| Author: | Vulcan [ May 5th, 2013, 14:40 ] |
| Post subject: | Re: how to remove zero track bad for seagate 340014a alpine. |
Have you got a (legitimate) PC-3000? If not, then you are posting in the wrong place... moiz h/d wrote: i think is this service track problem Why exactly do you think that? Please list all of the tests that you have done, the results of those tests, and your interpretation of those results. Without clear and unambiguous explanations from you, we don't know why you think this is an SA problem... |
| Author: | moiz h/d [ May 5th, 2013, 14:54 ] |
my drive show green and red blocks from starting sectors and i am gone to check the drive is victoria so drive is now hang and show bsy bsy |
| Author: | Vulcan [ May 5th, 2013, 15:14 ] |
@moiz h/d, I was writing some more info, but I'll stop here since you are getting lots of advice from Spildit and I don't want you to be overloaded with questions / advice. Good luck! |
| Author: | moiz h/d [ May 5th, 2013, 15:37 ] |
this is the terminal log data Interface task reset 1024k x 16 buffer detected ALPINE - 1_Disk M-21 11-25-03 18:53 Head Mask FFFF - Switch to full int. Spin Ready 8.16 03-09-04 14:03 (P)PATA Reset Master T>N1 Missing Critical Parameter Code - FB Track 0EB9C.0.007 Sns 006 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000 T>Interface task reset 1024k x 16 buffer detected ALPINE - 1_Disk M-21 11-25-03 18:53 Head Mask FFFF - Switch to full int. Spin Ready 8.16 03-09-04 14:03 (P)PATA Reset Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master AT Er 00 Nwt Er 1b RdWr 004b.00.0000 ATA St d0 Er 00 Op 42 e, 000dc00,0001 0000 0000 Niwot: 0000dc00 16 0000dc00.0.000 0000 8000 0200 0100 CE Log EC=1b Rtype=0 OV=0 STStatus0 AT Er 00 Nwt Er 1b RdWr 004b.00.0000 ATA St d0 Er 00 Op 42 e, 000dc00,0001 0000 0000 Niwot: 0000dca7 16 0000dca7.0.000 0000 8000 02a7 0100 CE Log EC=1b Rtype=0 OV=0 STStatus0 AT Er 00 Nwt Er 1c RdWr 004b.00.0000 ATA St d0 Er 00 Op 42 e, 000dc00,0001 0000 0000 Niwot: 0000dca8 16 0000dca8.0.000 0000 8000 02a8 0100 CE Log EC=1c Rtype=0 OV=0 STStatus0 AT Er 00 Nwt Er 47 RdWr 004b.00.0000 ATA St d0 Er 10 Op 42 e, 000dc00,0001 7eff 0000 Niwot: 0000dc00 1a 0000dc00.0.000 0000 8000 0600 033e (P)(H)PATA Reset Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master Interface task reset 1024k x 16 buffer detected ALPINE - 1_Disk M-21 11-25-03 18:53 Head Mask FFFF - Switch to full int. Spin Ready 8.16 03-09-04 14:03 (P)PATA Reset Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master T> T>l1 Command Inactive - No VALID Cert Code Detected T>L1 T>f T> T> T> T> T>/f T>/1 1>/2 2>/3 3>N1 Command Inactive - No VALID Cert Code Detected 3>f ALPINE - 1_Disk 8.16 03-09-04 14:03 Built for ALPINE,GRAND2,Diamondback,TI1761 PreAmp,STL6 Andante PreAmp,InternalSpin,GC110,SVC123AC,OneToOne,2Disk,LowDelta,220 Servos,7200RPM,8Pole,NonModGray,100MHz,Code DRAM,Early Exit,Stall Converter,RwFeat=0200,SeaDex,MDW :5000001820040000 AX`3JX9KTLV "000000000000"0EB70-0EBEF SRAM Ovly = Diag Pgm=00 Trk=14FC6(15050).0(0).11A(39A) Zn=E Err=00 ErCt=0000 Hlth=0018 CHlth=0000 Ntrdy LBA=0000DC3E [[[(S)PATA Reset Interface task reset 1024k x 16 buffer detected ALPINE - 1_Disk M-21 11-25-03 18:53 Buzz - Head Mask FFFF - Switch to full int. Spin Ready 8.16 03-09-04 14:03 (P)PATA Reset Master (S)PATA Reset CE Log EC=0 Rtype=9 OV=0 STStatus0 Master |
| Author: | moiz h/d [ May 5th, 2013, 16:32 ] |
i dont need data i just want to repair my hdd did u tell me seagate comand for working seagate hdd plzz like head deppop and head cut and other |
| Author: | moiz h/d [ May 6th, 2013, 1:56 ] |
spildit did u tell me what is vendor track and app code ??? my pc3k menu is shown writing service track so i presss the writing st show me more option app code and like vendor code and etc ?? |
