Page 1 of 1
Deepspar Add-on
Posted: May 11th, 2013, 15:15
by ccieandrew
Not a PC3000 question but this is the closest
Would like to get feedback if you used USB add-on.
Success rate with out using PC-3000
Re: Deepspar Add-on
Posted: May 13th, 2013, 18:37
by quasimodo
I am not impressed with it!
Re: Deepspar Add-on
Posted: May 14th, 2013, 9:15
by lcoughey
I use it every day.
Re: Deepspar Add-on
Posted: May 15th, 2013, 15:10
by bcometa
We use it occasionally, but wouldn't find it too helpful if we didn't also have a pc3k to fix firmware problems. Swapping to SATA always seems more reliable and faster when the drive has lots of bad sectors. But, if the drive is in pretty good shape, it's more convenient to clone "unencrypted" and skip the later step of decrypting the clone.
Re: Deepspar Add-on
Posted: May 17th, 2013, 8:57
by Nick_CT
I've found it works well with Toshiba and Samsung native USB drives with degraded media, but WDs are a different story.
Tool does work well for the correct applications.
Re: Deepspar Add-on
Posted: June 5th, 2013, 22:36
by craig6928
quasimodo wrote:I am not impressed with it!
how come you dont like it ????
that add on somewhere between $2,400
Re: Deepspar Add-on
Posted: June 6th, 2013, 10:50
by quasimodo
Pretty much what bcometa said,
bcometa wrote:We use it occasionally, but wouldn't find it too helpful if we didn't also have a pc3k to fix firmware problems. Swapping to SATA always seems more reliable and faster when the drive has lots of bad sectors. But, if the drive is in pretty good shape, it's more convenient to clone "unencrypted" and skip the later step of decrypting the clone.
It's really only useful if the drive has minor issues, and most drives we get in for recovery are way past minor issues. Most have been dropped, have platter damage, etc... After replacing heads reading via USB command set is just not something I think is a good idea (at least in the current implementations). And if you switch the USB add on to use ATA command set, now your dealing with the encrypted drive, in which case it's a lot better to just go sata and maintain as much control as possible over the drive.
