Loader Tahoe LT
http://forum.hddguru.com/viewtopic.php?f=11&t=26034
Author:  sempre [ May 15th, 2013, 8:56 ]
Post subject:  Loader Tahoe LT
Hi to all!!
Please loader WD3200AAKS-00UU3A0
Thanks!!
:mrgreen:
Author:  sempre [ May 15th, 2013, 9:35 ]
Post subject:  Re: Loader Tahoe LT
sempre wrote:
Hi to all!!
Thanks!!
:mrgreen:
Techno mode key
>Techno mode key......................... : Ok
!Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 1
>Cyl Count............................... : 256
!Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 00.0JB
>ROM generation.......................... : 00.0JB
>Link table version...................... : 03.0B.
>Consolidated ROM version................ : 0000000J
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir (ext) reading............. : Ok (Active)
>Modules directory address............... : 156 336 (24)
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number............................ : 2
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 0000000J
>Service area:
!SA dir reading (ID)..................... : Drive is not ready
!SA dir reading (ABA/CHS)................ : Module 0001 reading error ABA 486576 reading error Physical read error C/H/S: 49/1/482 Device Error Detected: "VSCE KEY SECTOR MUST PRECEED DATA XFER REQUEST"
>SA Access............................... : NONE
Author:  labtech [ May 15th, 2013, 10:59 ]
http://files.hddguru.com/download/PC-30 ... ahoe%20LT/
Seems there is a database file in there matching your ver.
