 Post subject: toshiba eeprom is burned
PostPosted: May 15th, 2013, 10:30
There is some method to reconstruct the eeprom on toshiba like WD. I have a case is a toshiba hd model mk5061gsy the eeprom is burned, I have 2 disk of the same model but the pcb is not fully compatible with the disk, when a exchange the pcb the disk do half boot.
I try to do a hot swap but unsuccessful.
I can do?
 Post subject: Re: toshiba eeprom is burned
PostPosted: May 15th, 2013, 10:47
You cannot rebuild Toshiba, as all the adaptive info is stored on the ROM. Odds are, you are not going to recover the data without the original ROM info. You can try the trial and error approach of trying to find a replacement PCB with a ROM that works with the drive.
Good luck.
PostPosted: May 15th, 2013, 11:31
thanks very much lcoughey.
PostPosted: May 15th, 2013, 14:58
Any Body has rom of mk5061gsy to send me?
I appreciate it a lot
thanks very much
