 Post subject: Need resource for WD10EARS
PostPosted: June 25th, 2013, 8:54
Hi to all
I need resource (modules) for WD10EARS-00MVWB1 Rom.Ver. 20.76E Fw. 00200076 with Heads Maps like 0,1,2,5,6,7
Some one can help me ?
Tnks
 Post subject: Re: Need resource for WD10EARS
PostPosted: June 26th, 2013, 3:31
Here you are:
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 6
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1980
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 20.76E
>ROM generation.......................... : 20.77E
>Link table version...................... : 0B.3B.
>Consolidated ROM version................ : 00200076
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Modules directory address............... : 108 041 (24)
>SA regions address...................... : by default
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,5,6,7
>ROM Firmware version.................... : 00200088
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
WDC WD10EARS-00MVWB0-51-0AB51-WD-WCAZA9884919.zip [12.1 MiB]
Downloaded 666 times
PostPosted: June 26th, 2013, 4:07
I try it. Thank you.
But that is for 00MVWB0, and i need for 00MVWB1
Bye
PostPosted: June 26th, 2013, 4:57
I dont think it makes any difference.
PostPosted: June 26th, 2013, 10:16
I try resource. They are good, but not solved my problem.
I description of my problem :
- Connect Hdd to Pc3Kudma and power on
- After some seconds, Hdd go to ready
- Run utility
- After 1 or 2 minutes utility start. (Very Very Slow like normal)
- I run "Slow Response" fix, but it cannot write 02 and 32 module. Nothing to do with this fix
- I start SA module Check and Backup. The process is very very slow (like 1 hour) but i can backup all module, and i see all module are OK
- Hdd ID is good. I see model, S/N and all other parameter
Seem all is ok, but Hdd is very very slow. I tried to read sectors, and all sectors i try are readed well.
I make Heads map for test Heads. I can read from all Heads.
The strange problem is that all seem to be good, but reading sectors is too slow for make clone or recovery data.
Someone can help my ?
Tnks to all.
PostPosted: June 26th, 2013, 11:00
Can read SMART values? What are those like? Just looking for more clues...
PostPosted: June 26th, 2013, 11:08
In fact if I try to read the SMART I get an error, but the modules 21, 23 and 24 are ok
PostPosted: June 27th, 2013, 3:07
Did you check cables?
Did you connect another known-good drive into the same configuration and see if it behaves normally?
Sometimes it's just the obvious.
After you did a head map on DE, did you let it run for 2-3 cycles to see if all heads read ok?
PostPosted: June 27th, 2013, 3:15
I just tried with donor PCB, but nothing change.
The problem is that i cannot write anything on SA.
If i try to write a module, the writing start very slow but end well without errors.
But if i re-read that module i see no change maked :shock:
I just tried with a secure donor drive, and it is good.
I do not never see a issue like this.
Tnks to all for help
PostPosted: June 27th, 2013, 9:27
You have right... i need to try Hot Swap.
I make it and after i tell you result
Tnks
