HDD GURU FORUMS
http://forum.hddguru.com/
WD1600AAJS-60M0A0 ineed rom or ldr files
http://forum.hddguru.com/viewtopic.php?f=11&t=26428
Page 1 of 1
Author:  drsc [ July 17th, 2013, 6:49 ]
Post subject:  WD1600AAJS-60M0A0 ineed rom or ldr files
hello my friends
wd1600aajs-60m0a0
ineed rom files or ldr files
thank you in advance
Author:  hddguy [ July 17th, 2013, 6:58 ]
Post subject:  Re: WD1600AAJS-60M0A0 ineed rom or ldr files
you need ROM OR loader? If ROM is not native version you will not reach access to data, if LDR is not native SA version it will not help.
what is its problem?
Author:  drsc [ July 17th, 2013, 7:23 ]
this hard drive ineed rom files
Author:  drsc [ July 17th, 2013, 7:27 ]
i need ony bin file i have pcb
Author:  thatdellguy [ July 17th, 2013, 7:34 ]
Look in hddguru files, It's been there since 2011.
Author:  hddguy [ July 17th, 2013, 10:55 ]
You have PCB, I assume from donor, but has no ROM already programmed to it? Also, how do you know what version you need? Why cant you use new PCB you have already? Unless its from some non-compatible family, but then you will need whole PCB
http://www.phpbb.com/
