| Does ST9250315AS Momentus 5400.6 250GB have terminal access? http://forum.hddguru.com/viewtopic.php?f=11&t=26758 |
Page 1 of 1 |
| Author: | Scorpion [ August 29th, 2013, 20:53 ] |
| Post subject: | Does ST9250315AS Momentus 5400.6 250GB have terminal access? |
Hi all, I have the following drive: Model : ST9250315AS Firmware : 0002BSM1 Capacity : 232.89 GB (488 397 168) Does the following has terminal access by PC3K terminal? The problem is that Ctrl + Z doesn't seem to work on that drive. The drive gives terminal reports but I can't set terminal commands for it. I am not sure if the problem is in my PC/PC3K unite or this drive doesn't has terminal access support. What do you think? Any terminal commands give the following terminal output: (S) SATA Reset Init SMART Fail LED:000000CC FAddr:00237E89 LED:000000CC FAddr:00237E89 LED:000000CC FAddr:00237E89 Best Regards, |
| Author: | Scorpion [ August 29th, 2013, 21:31 ] |
| Post subject: | Re: Does ST9250315AS Momentus 5400.6 250GB have terminal acc |
Thank you, I solved the case |
