 Post subject: PC3K UDMA or EXPRESS ...
PostPosted: June 5th, 2013, 13:49
Hello guys,
I have to buy a PC3K with DE but i would like to have your opinion between the UDMA version available and the EXPRESS version available in one month ... The speed is not a problem for me ... They say the software is the same just the card is different, could you confirm it ? Do you know if they will follow the updates of UDMA (they say yes because it is the same software) ?
Any advice would be great ...
Many thanks
Alain
 Post subject: Re: PC3K UDMA or EXPRESS ...
PostPosted: June 5th, 2013, 15:28
As it won't be released for another month, I suspect that nobody here has seen the express version. So, the only people qualified to answer your questions, at this point in time, are the folks at Ace. If the only difference between the products is the speed, I would suggest that price might be your deciding factor.
PostPosted: June 5th, 2013, 16:20
I think I have heard support and updates for UDMA will end after some period
PostPosted: June 5th, 2013, 16:24
Thanks ... i have also heard something like this but the girl from the sale at ACE say no it is the same software than EPRESS version ??? That could be a reason to spend more money in EXPRESS version ...
PostPosted: June 5th, 2013, 17:32
I have not confirmed this, and I am not speaking on behalf of Ace labs, but rumors are:
    1. They will continue to support on UDMA for approximately 2 years.
    2. Express will have 4 SATA ports instead of 2 IDE ports. Therefore you can work with a greater quantity of drives
    3. Will support UDMA 133, therefore it will be faster than the previous model.
    4. Price will be approx. 150% of Pc3K UDMA.
Hope this helps!
PostPosted: June 6th, 2013, 7:00
Ace does not officially say that UDMA will stop being updated/supported. They also say the reason PC3K-PCI was discontinued was that it has been hacked/cloned by chinese clone. They also still sell UDMA, which means that if they suddenly announce end of life, many people will get angry.
Personally I hope they will still support / update UDMA for many years, but no one can be certain.
By the way, Express has 6 ports, not 4. 4*SATA + 2*IDE. But you can work with 4 drives at the same time though (ie. 4*SATA or 3*SATA + 1*IDE or 2*SATA + 2*IDE).
Price is indeed 1.5 times more than UDMA.
PostPosted: June 6th, 2013, 10:41
Yes you are correct, 6 ports. But since you can only use 4 active ports at once, I did not count the other 2 dormant ports.
PostPosted: October 12th, 2013, 3:54
I have PC3000 UDMA, recently bought a PC3000 EXPRESS. Their functions are the same, but more EXPRESS port. Maximum copy speed UDMA 133, supports 64-bit operating system, which is very effective to restore more than 3TB hard drive
PostPosted: October 15th, 2013, 2:36
Can you clarify "express" ports??
PostPosted: October 15th, 2013, 4:21
UDMA has 2 ata ports
EXPRESS has 4 sata ports (or 2x sata 2x ata or 3 sata 1x ata depending what you choose on startup)
there is no such thing as "express" port, he meant more port on "express" card
This post was my opinion today. It cant be used against me in tomorrow or later. In addition, I reserve the right to change views without giving any reason.
PostPosted: October 18th, 2013, 4:55
Hi
This is a photo of new version of PC3000
Source: Iranian partner of acelaboratory.
