HDD GURU FORUMS
http://forum.hddguru.com/
HDS5C3020ALA632 family
http://forum.hddguru.com/viewtopic.php?f=11&t=27331
Page 1 of 1
Author:  pclab [ November 21st, 2013, 9:12 ]
Post subject:  HDS5C3020ALA632 family
Hi
I have this HDD wich clicks.
I have checked heads and platters, they seem fine.
When connected to UDMA, it clicks but after a few moments it goes ready.
When I try to select the family, it doesn't recognize it?
This is a new family unsupported?
Can I try to disable heads, to see if I can get any files?
Author:  dmarques [ November 22nd, 2013, 12:11 ]
Post subject:  Re: HDS5C3020ALA632 family
I think PC3K is not yet supporting those families.
But you can add it manually if have the necessary info.
Author:  pclab [ November 22nd, 2013, 15:34 ]
Hi
It's a ARM utility family.
Case solved.
Author:  dmarques [ November 23rd, 2013, 11:05 ]
Nice.
So what was the issue with it?
Author:  pclab [ November 25th, 2013, 15:11 ]
I could edit NVRAM and disable the bad head.
http://www.phpbb.com/
