Any tip on how to read faster from damaged drive?
Posted: December 21st, 2013, 9:36
I'm working with a Hitachi HTS541010A9E680 drive which fell off the table and stopped being recognized - well, kind of obvious. Using PC3k I have imaged H0, H1, and H2 so far. But H3 is damaged and although I can read without ECC uncorrectable errors (all light green in DE), it reads at a rate of 1-2 LBAps. Autoreassign in HDD configuration is switched off. In your experience, is there anything else I can do before replacing HSA? Reading through the Utility (task params options) does not ask for any further configuration and says "activated successfully" straight away, reducing speed to about 0.2 LBAps - it seems to read sector by sector, instead of issuing n-block reading commands.
Cheers
Cheers
