 Post subject: WD3200BPTV-24JJ5T0 spin well but can't read SA
PostPosted: January 22nd, 2014, 12:23
I've a WD3200BPTV-24JJ5T0 drive. it spin well, no clicks.
When I connect it to PC3000, it can't read ID even in Kernel mode:
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 65.48K
ROM generation.......................... : 65.48K
Link table version...................... : 05.0H.
Consolidated ROM version................ : 00650048
ROM Modules:
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
[b][color=#FF0000]SA defects assigned..................... : 2[/color][/b]
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 00650048
When I try to read modules by ABA, I get the output bellow:
Module search process started
Search method........................... : Search by ABA
ABA..................................... : 0
Size in sectors......................... : 168 148
ABA 0 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 1 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 2 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 3 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 4 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 5 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 6 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 7 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 8 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 9 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 10 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 11 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 12 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 13 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 14 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 15 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules found........................... : 0
Module search process completed
Could it be a Bad Head that should be replaced?
Kind regards,
 Post subject: Re: WD3200BPTV-24JJ5T0 spin well but can't read SA
PostPosted: January 23rd, 2014, 3:48
Many thanks for your help Spildit.
Yes, I tried a loader from a share that I found on this website (http://files.hddguru.com/download/PC-30 ... ica%204KV/)
I have the save FW version as this file. but unfortunately, I got the same error "ABA 15 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended""
reading by ID, I got the ABR error.
The drive spins very well and very quite. no noise.
PostPosted: January 26th, 2014, 9:25
The Patient drive is:
MDL: WD3200BPVT-24JJ5T0
DCM: SHMTJAB
DCX: TJ03J975Y
Date: 12 JAN 2012
FW: 01.01A01
The donor drive is:
DCM: HEMTJABB
DCX: 5J04J9456
Date: 05 OCT 2011
FW: 02.01A02
Could this donor be a good one for HOT SWAP even if the FW version is not the same?
PostPosted: January 26th, 2014, 10:27
I admit it's a weird problem I have:
In PC3000, When I go to "Tests » Service information » Work with service area » Hardware module checking"; it can read modules except modules 11, 33 "P-List (Primary defect list)", 31 "Translator", 43 "Adaptive data" and other not important modules :roll: .
Hardware modules checking
Id   : Copy 0     : Copy 1     : Desription
0001 : Ok         : Ok         : Modules directory
0035 : Ok         : Ok         : SA Defects
006D : Ok         : Ok         :
0110 : Ok         : Ok         : Modules directory (base part)
0102 : Ok         : Ok         : Heads map module image
0103 : Ok         : Ok         : ROM adaptives SA images
0104 : Ok         : Ok         : Microprogram version image
0105 : Ok         : Ok         : ROM translator SA images
0107 : Ok         : Ok         : ROM module image
0106 : Ok         : Ok         : ROM module image
0108 : Ok         : Ok         : IBI packet
0002 : Ok         : Ok         : Configuration (HDD ID)
0017 : Ok         : Ok         : Loaded part of microprogram code
001B : Ok         : Ok         : Loaded part of microprogram code
001C : Ok         : Ok         : Loaded part of microprogram code
0014 : Ok         : Ok         : Loaded part of microprogram code
0015 : Ok         : Ok         : Loaded part of microprogram code
001E : Ok         : Ok         : Loaded part of microprogram code
002F : Ok         : Ok         : Loaded part of microprogram code
002A : Ok         : Ok         : Loaded part of microprogram code
0021 : Ok         : Ok         : S.M.A.R.T.
0022 : Ok         : Ok         : S.M.A.R.T.
0023 : Ok         : Ok         : S.M.A.R.T. Log (reserved)
0024 : Ok         : Ok         : S.M.A.R.T. Log (reserved)
0013 : Ok         : Ok         : Loaded part of microprogram code
0011 : Err: 02    : Err: 02    : Loaded part of microprogram code
0019 : Ok         : Ok         : Loaded part of microprogram code
0012 : Ok         : Ok         : Loaded part of microprogram code
0050 : Ok         : Ok         : Parameters table 1
0051 : Ok         : Ok         : Parameters table 2
0052 : Ok         : Ok         : Parameters table 3
0053 : Ok         : Ok         : Parameters table 4
0109 : Ok         : Ok         : ROM image
0062 : Ok         : Ok         :
001F : Ok         : Ok         : Loaded part of microprogram code
006E : Ok         : Ok         : Loaded part of microprogram code
0116 : Ok         : Ok         :
0118 : Ok         : Ok         :
AC55 : Ok         : Ok         :
4002 : Ok         : Ok         :
0122 : Ok         : Ok         :
0081 : Ok         : Ok         :
80FC : Ok         : Ok         :
0033 : Err: 02    : Err: 02    : P-List (Primary defect list)
0031 : Err: 02    : Err: 02    : Translator
000C : Ok         : Ok         : Models table
0034 : Ok         : Ok         : G-List (Grown defect list)
0032 : Ok         : Ok         : Relo-List (Candidate defects)
0036 : Ok         : Ok         : T-List Module
0029 : Ok         : Ok         : Loaded part of microprogram code
0040 : Ok         : Ok         : Adaptive data
0041 : Ok         : Ok         : Adaptive data
0042 : Ok         : Ok         : Adaptive data
0043 : Err: 02    : Ok         : Adaptive data
004E : Ok         : Ok         : Loaded part of microprogram code
0049 : Ok         : Ok         : Adaptive data
004A : Ok         : Ok         : Adaptive data
004D : Ok         : Ok         : Adaptive data
0003 : Ok         : Ok         : Format Select Data Module
0025 : Ok         : Ok         :
0026 : Ok         : Ok         :
0038 : Ok         : Ok         : Loaded part of microprogram code
0039 : Err: 02    : Ok         : Loaded part of microprogram code
0037 : Ok         : Ok         : Gain Call Data Module
002D : Ok         : Ok         : Debug Log
002E : Ok         : Ok         : Loaded part of microprogram code
00B5 : Ok         : Ok         : WRRO Log Module
006B : Ok         : Ok         : Loaded part of microprogram code
003A : Ok         : Ok         :
0028 : Ok         : Ok         : Factory Self Test script
003B : Ok         : Ok         :
003C : Ok         : Ok         :
003D : Ok         : Ok         :
003E : Ok         : Ok         :
003F : Ok         : Ok         :
006F : Err: 02    : Err: 02    :
0119 : Ok         : Ok         :
0068 : Ok         : Ok         :
0069 : Ok         : Ok         :
006A : Ok         : Ok         :
0121 : Err: 02    : Err: 02    :
0128 : Ok         : Ok         :
012A : Ok         : Ok         :
0120 : Err: 02    : Err: 02    :
012D : Ok         : Ok         :
022D : Ok         : Ok         :
0004 : Err: 02    : Err: 02    : Family models configuration (Main)
0123 : Ok         : Ok         :
0124 : Ok         : Ok         :
0125 : Ok         : Ok         :
0126 : Ok         : Ok         :
D002 : Ok         : Ok         :
D003 : Ok         : Ok         :
D004 : Ok         : Ok         :
D005 : Ok         : Ok         :
D000 : Ok         : Ok         :
D001 : Ok         : Ok         :
0127 : Ok         : Ok         :
D006 : Ok         : Ok         :
0063 : Ok         : Ok         :
0115 : Ok         : Ok         :
01   : Module has invalid header
02   : Data error reading module
03   : Servo error reading module
04   : Wrong / Incompatible module
05   : The two copies do not match / Checksums Different
06   : Invalid checksum
07   : Module state reading error
Is there any chance that Hot swap procedure will succeed with the donor drive I mention above ?
Anyone who have a compatible loader with the Patient drive I mention above?
Kind regards,
PostPosted: January 27th, 2014, 12:02
I don't know. The date code on your donor is pretty far off. I personally would look for one with a closer date, otherwise you might be spinning your wheels and getting nowhere.
PostPosted: January 27th, 2014, 14:12
Op will need to hotswap in order to access modules via ABA and can read in composite. this way you may salvage enough of 31 to be ok. IF not, and dependent on how much is read before errors, you can cut the translator size as long as it header and checksum is is adjusted. After some point module is filled with 00 anyway.
Donor should be good hotswap donor, sometimes modules can have different SA and sizes of modules may vary, if this is the case with your donor find some resource in database with compatible sa and write tracks and rom to make donor compatible for hotswap.
If DIR module is different write patient one to RAM to ensure mods are accessed correctly.
Once you reach good copy of required modules you can make smart hotswap with same donor to reach data.
Also, with each of these steps is the risk of causing more damage to patient and 'brick' your donor. If you are unsure about any of it, it could be best to outsource it
