 Post subject: Loader for SadleD2 WD10EARX-00N0YB0
PostPosted: February 5th, 2014, 8:31
Hi
Need a loader for a WD10EARX-00N0YB0.
ROM Data size........................... : 256 Kb
ROM version............................. : 51.53A
ROM generation.......................... : 51.53A
Link table version...................... : 0A.02.
Consolidated ROM version................ : 00510053
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 382 437
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads number............................ : 3
Heads number in use..................... : 3
Switched off heads...................... : No
Heads map............................... : 0,1,3
ROM Firmware version.................... : 00510053
ACELab partner
 Post subject: Re: Loader for SadleD2 WD10EARX-00N0YB0
PostPosted: February 5th, 2014, 8:42
here you go
good luck :>
11.rar [341.09 KiB]
Downloaded 568 times
PostPosted: February 5th, 2014, 8:52
Thank You
ACELab partner
PostPosted: February 5th, 2014, 9:04
Most welcome
Users browsing this forum: No registered users and 120 guests
