HDD GURU FORUMS
http://forum.hddguru.com/
WD drive hangs if reading at high speed
http://forum.hddguru.com/viewtopic.php?f=11&t=27984
Page 1 of 1
Author:  PAKComputers [ February 17th, 2014, 10:46 ]
Post subject:  WD drive hangs if reading at high speed
I have a WD Spider drive that acts normally if you read at a slow pace (< 50KB/sec)
If I try to read any faster, the drive locks, and I must do either a hardware reset of power cycle to continue reading.
Any help is a appreciated
Author:  ROb [ February 28th, 2014, 3:16 ]
Post subject:  Re: WD drive hangs if reading at high speed
I am not an expert but Did you try WD SLOW READING Solution ???
It should solve your problem
http://www.phpbb.com/
