Samsung Terminal plug?
http://forum.hddguru.com/viewtopic.php?f=11&t=28136
Author:  Oyster55 [ March 10th, 2014, 13:27 ]
Post subject:  Samsung Terminal plug?
Hi, I have a Samsung HD321KJ and I want to read the terminal output
but am confused as to which plug goes in to the terminal/serial connector.
I only have a 4-pin Terminal connector labeled "Samsung"
Am I missing an 8-pin block type connector?
If yes, how can I order one?
Author:  digisupport [ March 10th, 2014, 14:21 ]
Post subject:  Re: Samsung Terminal plug?
Look in your Samsung manual for pc3k, there you see how to connect treminal using the seagate adapter.
Author:  labtech [ March 11th, 2014, 9:55 ]
Search elektroda
Author:  fzabkar [ March 11th, 2014, 17:33 ]
I would refer you to a particular thread at the HDD Oracle forum, but it appears to be offline again. :-(
Anyway, here are some of the commands:
http://malthus.zapto.org/viewtopic.php? ... 1997#p1997
Author:  Oyster55 [ March 12th, 2014, 14:53 ]
Thanks, all. I got it now: Use the Seagate-labelled 3X2 plug on the left-most 6pins and remove the 2-pin shunt to the right.
