Discussions related to PC-3000
Please no pirated software here!
need help WD5000AAKS
March 24th, 2014, 16:14
guys I'm new to working with the PC-3000.
need your help!
drive in normal mode is not detected. in the kernel mode outputs
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 12.16D
ROM generation.......................... : 12.16D
Link table version...................... : 04.09.
Consolidated ROM version................ : 00120016
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 156 335
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 5
Heads configuration..................... : by map
Heads number............................ : 2
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 00120016
please tell me what to do next to get it back to life
Re: need help WD5000AAKS
March 24th, 2014, 17:06
Is the drive still spinning, or has it spun down?
March 24th, 2014, 17:42
pcimage wrote:Is the drive still spinning, or has it spun down?
at power on hdd starts spinning
stops after 2 minutes
autodetection produces an error
• put three jumpers and fall on the power again
• manually run the utility WDC Marvell
• mode karnel
• autodetect (hdd is determined Tahoe)
• ok, utility start
Techno mode key
RAM:
ROM:
ROM Modules:
March 24th, 2014, 18:04
Probably damaged fw (usually mod 11).
Use LDR to access fw and find damaged module(s)
March 25th, 2014, 3:09
pcimage wrote:Probably damaged fw (usually mod 11).
Thank you for your help
what do I need to do?
downloaded LDR from the database?
