| need help WD5000AAKS http://forum.hddguru.com/viewtopic.php?f=11&t=28251 |
Page 1 of 1 |
| Author: | shihzur [ March 24th, 2014, 16:14 ] |
| Post subject: | need help WD5000AAKS |
guys I'm new to working with the PC-3000. need your help! drive in normal mode is not detected. in the kernel mode outputs Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 1 Cyl Count............................... : 256 ROM: ROM reading............................. : Ok ROM Data size........................... : 192 Kb ROM version............................. : 12.16D ROM generation.......................... : 12.16D Link table version...................... : 04.09. Consolidated ROM version................ : 00120016 ROM Modules: Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 156 335 SA regions address...................... : by default SA Translator loading................... : Ok SA defects assigned..................... : 5 Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Heads map............................... : 0,1 ROM Firmware version.................... : 00120016 please tell me what to do next to get it back to life |
| Author: | pcimage [ March 24th, 2014, 17:06 ] |
| Post subject: | Re: need help WD5000AAKS |
Is the drive still spinning, or has it spun down? |
| Author: | shihzur [ March 24th, 2014, 17:42 ] |
pcimage wrote: Is the drive still spinning, or has it spun down? at power on hdd starts spinning stops after 2 minutes autodetection produces an error • put three jumpers and fall on the power again • manually run the utility WDC Marvell • mode karnel • autodetect (hdd is determined Tahoe) • ok, utility start Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 1 Cyl Count............................... : 256 ROM: ROM reading............................. : Ok ROM Data size........................... : 192 Kb ROM version............................. : 12.16D ROM generation.......................... : 12.16D Link table version...................... : 04.09. Consolidated ROM version................ : 00120016 ROM Modules: Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 156 335 SA regions address...................... : by default SA Translator loading................... : Ok SA defects assigned..................... : 5 Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Heads map............................... : 0,1 ROM Firmware version.................... : 00120016 |
| Author: | pcimage [ March 24th, 2014, 18:04 ] |
Probably damaged fw (usually mod 11). Use LDR to access fw and find damaged module(s) |
| Author: | shihzur [ March 25th, 2014, 3:09 ] |
pcimage wrote: Probably damaged fw (usually mod 11). Use LDR to access fw and find damaged module(s) Thank you for your help what do I need to do? downloaded LDR from the database? |
