 Post subject: Resources for Dragon Ver 0020001G
PostPosted: April 10th, 2014, 13:32
Looking for mod 11 and mod 36 for WD30EZRS-00J99B0, Dragon Family, Ver 0020001G, please.
Thanks in advance
 Post subject: Re: Resources for Dragon Ver 0020001G
PostPosted: April 11th, 2014, 4:04
Here are those mods from 2.5Tb version, but should work OK.
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 7
>Cyl Count............................... : 192
>Zone allocation table................... : Ok
>SA SPT.................................. : 1988
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 20.1GP
>ROM generation.......................... : 20.1HP
>Link table version...................... : 0B.38.
>Consolidated ROM version................ : 0020001G
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir (ext) reading............. : Ok (Active)
>Modules directory address............... : 283 719 (24)
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number............................ : 8
>Heads number in use..................... : 7
>Switched off heads...................... : Yes
>Heads map............................... : 0,1,2,4,5,6,7
>ROM Firmware version.................... : 0020001G
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [339.66 KiB]
Downloaded 462 times
36.rar [297 Bytes]
Downloaded 432 times
PostPosted: April 11th, 2014, 9:20
Thank you.
Sent PM.
