Hi there.
I'm doing remote assistence on a Samsung Spinpoint drive that stays at BSY.
The "client" only have PC3K Express.
I've checked the drive and on the LOG window i get FIPS checksum error.
I've went to terminal and issue the "esc" to drop the drive to degug mode (dbg) and i've downloaded the ROM by terminal.
When i go to offset 70000 i see that it's cleared out, so i patched FIPS on the ROM but I CAN'T WRITE to ROM (i can only READ) with terminal.
Am i doing something wrong ?
On the menu of PC3K i can see Read ROM by terminal and WRITE ROM. Does it mean that the operation to write ROM using UDMA/EXPRESS only works with ATA access ?
I've tryed to write to ROM and then read again, by the reading is the same rom i started with, in other words, it didn't wrote the edited/patched ROM.
If the drive is stuck at BSY and ATA (on the express case the SATA0 connection) is not working can't i just flash ROM by terminal the same way i read from terminal ?
I'm assumining correctly that PC3K needs the ATA interface to be working to write ROM ?
The sollution for this case apears to be for the client to buy an external programmer so i can write the patched ROM file back to it.
Any way to write ROM using PC3K when ATA interface is stuck at BSY ?
I've done several ROM patching for fixing the FIPS issue, but i've allways used the external programmer (i'm Takanashi_Hina at Acelab Forum) .
http://acelaboratory.ru/forum/viewtopic.php?f=33&t=8126The question is, can i programm the ROM using JUST PC3K if ATA is bsy ?
Regards.
