| Need ROM and loader from WD5000AZRX-L4H http://forum.hddguru.com/viewtopic.php?f=11&t=28572 |
Page 1 of 1 |
| Author: | deftrue [ May 9th, 2014, 7:57 ] |
| Post subject: | Need ROM and loader from WD5000AZRX-L4H |
Hello, Something's wrong with this HDD's ROM (SA translation error - UBA 0 out of translation + reading errors on ROM modules 30 and 47). I need a matching FW ROM and possibly a loader. I'd really appreciate any help. Here are the details: ROM: ROM reading............................. : Ok ROM Data size........................... : 256 Kb ROM version............................. : 01.34G ROM generation.......................... : 01.34G Link table version...................... : 22.30. Consolidated ROM version................ : 00010034 ROM Modules: Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 208 636 SA regions address...................... : spared SA Translator loading................... : Ok Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 1 Switched off heads...................... : Yes Heads map............................... : 0 ROM Firmware version.................... : 00010034 The drive is a TrailXLS, model WD5000AZRX with family + configuration code 00L4HB0. Thank you very much in advance. |
