| Need help calculating WD module checksum http://forum.hddguru.com/viewtopic.php?f=11&t=28575 |
Page 1 of 1 |
| Author: | PAKComputers [ May 9th, 2014, 16:11 ] |
| Post subject: | Need help calculating WD module checksum |
I have a WD3200BEKT with an inaccessable loader. I found the module by reading track -135. According to module 02, the size is 511, so I extracted 261,632 bytes to 11.rpm starting with the ROYL header. The problem is when I send the ldr to the drive, I get a OVL CHECKSUM error How do you calculate the checksum ? Does anyone have a program (or source code) to calc the checksum ? |
| Author: | fzabkar [ May 9th, 2014, 16:34 ] |
| Post subject: | Re: Need help calculating WD module checksum |
I previously uploaded a free checksum calculator that was written by Pete Disdale: download/file.php?id=4921 The checksum is a 32-bit little-endian sum over the module's contents. It should be 0. |
