 Post subject: Need help calculating WD module checksum
PostPosted: May 9th, 2014, 16:11
I have a WD3200BEKT with an inaccessable loader.
I found the module by reading track -135.
According to module 02, the size is 511, so I extracted 261,632 bytes to 11.rpm starting with the ROYL header.
The problem is when I send the ldr to the drive, I get a OVL CHECKSUM error
How do you calculate the checksum ?
Does anyone have a program (or source code) to calc the checksum ?
 Post subject: Re: Need help calculating WD module checksum
PostPosted: May 9th, 2014, 16:34
I previously uploaded a free checksum calculator that was written by Pete Disdale:
download/file.php?id=4921
The checksum is a 32-bit little-endian sum over the module's contents. It should be 0.
