Seagate ST2000DM001 - Recognize But Don't read any sector...
http://forum.hddguru.com/viewtopic.php?f=11&t=28665
Author:  pauloanbraga [ May 20th, 2014, 12:43 ]
Post subject:  Seagate ST2000DM001 - Recognize But Don't read any sector...
I have a Seagate HD and only remained in a busy state. I short the pins, acesss terminal and recover the translator.
Now the HDD recognizes normally (in PC3K utility) and is in READY, but not read any sector.
I need to recover the data and I send below the terminal message:
Can someone help me?
Boot 0x40M
Spin Up
TCC-0022[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0022
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00000008
[RSRS] 0000
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 00000001
MCMainPOR: Feature Enabled...
(DOS)STE OGHT: 0x00000000000DC973 - 0x00000000000DD0D4 - 0x00000301 - 0x0000031F Count 0052
(DOS)CMP Count 0052
(DOS)STE OGHT: 0x000000000014E525 - 0x000000000014FE74 - 0x00000301 - 0x0000031F Count 0052
(DOS)CMP Count 0052
(DOS)STE OGHT: 0x0000000000183279 - 0x0000000000184424 - 0x00000407 - 0x00000425 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000001BCCE5 - 0x00000000001BE55C - 0x00000407 - 0x00000425 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x000000000014A141 - 0x000000000014C784 - 0x00000339 - 0x00000357 Count 005B
(DOS)CMP Count 005B
(DOS)STE OGHT: 0x000000000C391BEC - 0x000000000C394536 - 0x0001C29D - 0x0001C2BB Count 0053
(DOS)CMP Count 0053
(DOS)STE OGHT: 0x000000000C391D41 - 0x000000000C39468B - 0x0001C29E - 0x0001C2BC Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x000000000C390148 - 0x000000000C392A92 - 0x0001C289 - 0x0001C2A7 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x000000000C392A93 - 0x000000000C392A92 - 0x00051E6C - 0x00051E8A Count 0062
(DOS)CMP Count 0062
(DOS)STE OGHT: 0x000000000C3907F1 - 0x000000000C39313B - 0x0001C28E - 0x0001C2AC Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x000000000014B63D - 0x000000000014DC80 - 0x0000034A - 0x00000368 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x000000000008DEEA - 0x0000000000090283 - 0x0000018B - 0x000001A9 Count 004C
(DOS)CMP Count 004C
(DOS)STE OGHT: 0x0000000000A264F0 - 0x0000000000A28E97 - 0x00001759 - 0x00001777 Count 004B
(DOS)CMP Count 004B
(DOS)STE OGHT: 0x00000000000F30A9 - 0x00000000000F5ACC - 0x0000026D - 0x0000028B Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x000000000010C923 - 0x000000000010ECBC - 0x00000241 - 0x0000025F Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x0000000000090038 - 0x00000000000923D1 - 0x000001A8 - 0x000001C6 Count 004E
(DOS)CMP Count 004E
(DOS)STE OGHT: 0x000000000C534532 - 0x000000000C536E00 - 0x0001CDF4 - 0x0001CE12 Count 0043
(DOS)CMP Count 0043
(DOS)STE OGHT: 0x000000000C39652F - 0x000000000C398E79 - 0x0001C2D4 - 0x0001C2F2 Count 0046
(DOS)CMP Count 0046
(DOS)STE OGHT: 0x000000000006E514 - 0x000000000006E927 - 0x00000159 - 0x00000177 Count 004A
(DOS)CMP Count 004A
(DOS)STE OGHT: 0x00000000000A71E8 - 0x00000000000A97F7 - 0x00000159 - 0x00000177 Count 004A
(DOS)CMP Count 004A
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Author:  Dmitri [ May 23rd, 2014, 14:53 ]
Post subject:  Re: Seagate ST2000DM001 - Recognize But Don't read any secto
Having the information above, I'd say that you have either missed and haven't done something or somehow wrecked non-resident list.
Author:  manhcuongvn [ June 4th, 2014, 5:11 ]
try:
/2
/Z
/U
T> m0,6,2,0,0,0,0,22
http://cuumaytinh.com
Author:  seotopgg [ January 15th, 2016, 9:55 ]
Địa chỉ cứu dữ liệu tại TPHCM
Author:  day1data [ January 18th, 2016, 5:54 ]
Is the drive detected as zero capacity?
99% sure this is a simple firmware fix.
