| WD3200B EVT / Strange vibration sound on power-on http://forum.hddguru.com/viewtopic.php?f=11&t=28739 |
Page 1 of 1 |
| Author: | killerchip [ May 29th, 2014, 7:23 ] |
| Post subject: | WD3200B EVT / Strange vibration sound on power-on |
Hello HDD Gurus Could I have your opinion on where to look next on the following situation? I have the following 2.5'' drive which stopped working: WD3200B EVT-22ZCT0 Parameters: LBA 625142448 R/N: 701499 DATE: 06 SEP 2008 DCM: HBNV2BB I turn on the drive and a small 'vibriation'-like-tune is heard. Not a click-clak, but like an attempt for the motor to start. After the tune is repeated four times, it then stops. I cannot feel any vibration by putting my hand on the drive. I tried to start the PC-3000 utility but it reports drive not ready. Even when I manually start the utility, selecting the 'Scorpio' family, it still reports an error about techno mode not ready. Any ideas, if I'm looking into 'open-the-case' case, or something else I could try before start looking for clean-room? Thank you very much in advance KC |
| Author: | pcimage [ May 29th, 2014, 7:27 ] |
| Post subject: | Re: WD3200B EVT / Strange vibration sound on power-on |
Stiction (heads stuck to platter) or heads mashed into ramp. |
| Author: | killerchip [ May 29th, 2014, 8:50 ] |
pcimage wrote: Stiction (heads stuck to platter) or heads mashed into ramp. Thank you very much ! |
