| Samsung with bad head?? http://forum.hddguru.com/viewtopic.php?f=11&t=28764 |
Page 1 of 1 |
| Author: | pclab [ June 2nd, 2014, 12:03 ] |
| Post subject: | Samsung with bad head?? |
Hi I got a HD253GJ with a problem on the PCB (it wouldn't spin up the platters). So I ordered a donor 3 months apart of date of manufacture. I have made a hot swap, but I get this terminal. This means Head is dead, right? Thanks PK_4 C:238004 H:0 SO_1 SpinStartUp: mcSpinRPM = 0 RPM at Handoff: 623 Temp : 19 degC SpinOk mS1 00000003 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 |
| Author: | fzabkar [ June 2nd, 2014, 16:41 ] |
| Post subject: | Re: Samsung with bad head?? |
pclab wrote: I got a HD253GJ with a problem on the PCB (it wouldn't spin up the platters). So I ordered a donor 3 months apart of date of manufacture. I have made a hot swap ... Why? Wouldn't you just need to transfer the patient ROM to the donor PCB? |
| Author: | MindMergepk [ June 3rd, 2014, 13:26 ] |
pclab wrote: Hi I got a HD253GJ with a problem on the PCB (it wouldn't spin up the platters). So I ordered a donor 3 months apart of date of manufacture. I have made a hot swap, but I get this terminal. This means Head is dead, right? Thanks PK_4 C:238004 H:0 SO_1 SpinStartUp: mcSpinRPM = 0 RPM at Handoff: 623 Temp : 19 degC SpinOk mS1 00000003 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 to me not a good choice for HOT SWAP... can you read the rom of patient and donor and show us Dump info ? |
| Author: | pclab [ June 4th, 2014, 4:01 ] |
MindMergepk wrote: pclab wrote: Hi I got a HD253GJ with a problem on the PCB (it wouldn't spin up the platters). So I ordered a donor 3 months apart of date of manufacture. I have made a hot swap, but I get this terminal. This means Head is dead, right? Thanks PK_4 C:238004 H:0 SO_1 SpinStartUp: mcSpinRPM = 0 RPM at Handoff: 623 Temp : 19 degC SpinOk mS1 00000003 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 VOP! PK_3 C:238004 H:0 UF 3 1stGrayErr Hd:0 to me not a good choice for HOT SWAP... can you read the rom of patient and donor and show us Dump info ? Hi Why not a good choice? |
| Author: | MindMergepk [ June 4th, 2014, 4:21 ] |
imagine i tried a hot swap on HD502HJ with same month of manufacturing and it was not compatible.. if you read rom of patient and donor and compare the dump info you will have the answer |
| Author: | northwind [ June 6th, 2014, 6:28 ] |
Why you do hotswap and not just swap rom from patient to donor pcb? Alternatively, you can use donor pcb directly and write overlays without swapping rom. |
| Author: | pclab [ June 6th, 2014, 6:54 ] |
I'l try that too. Thanks |
