 Post subject: Samsung with bad head??
PostPosted: June 2nd, 2014, 12:03
Online
Hi
I got a HD253GJ with a problem on the PCB (it wouldn't spin up the platters).
So I ordered a donor 3 months apart of date of manufacture.
I have made a hot swap, but I get this terminal.
This means Head is dead, right?
PK_4 C:238004 H:0
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 623
Temp : 19 degC
SpinOk
mS1 00000003
UF 3 1stGrayErr Hd:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
ACELab partner
 Post subject: Re: Samsung with bad head??
PostPosted: June 2nd, 2014, 16:41
I have made a hot swap ...
Why? Wouldn't you just need to transfer the patient ROM to the donor PCB?
PostPosted: June 3rd, 2014, 13:26
pclab wrote:
Hi
PK_4 C:238004 H:0
SO_1
RPM at Handoff: 623
Temp : 19 degC
SpinOk
mS1 00000003
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
to me not a good choice for HOT SWAP...
can you read the rom of patient and donor and show us Dump info ?
Data Recovery Pakistan
PostPosted: June 4th, 2014, 4:01
Online
MindMergepk wrote:
pclab wrote:
Hi
PK_4 C:238004 H:0
SO_1
RPM at Handoff: 623
Temp : 19 degC
SpinOk
mS1 00000003
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
VOP!
PK_3 C:238004 H:0
Hi
Why not a good choice?
ACELab partner
PostPosted: June 4th, 2014, 4:21
imagine i tried a hot swap on HD502HJ with same month of manufacturing and it was not compatible..
if you read rom of patient and donor and compare the dump info you will have the answer
PostPosted: June 6th, 2014, 6:28
Why you do hotswap and not just swap rom from patient to donor pcb?
Alternatively, you can use donor pcb directly and write overlays without swapping rom.
PostPosted: June 6th, 2014, 6:54
Online
I'l try that too.
ACELab partner
