| Seagate 500GB No Terminal Access http://forum.hddguru.com/viewtopic.php?f=11&t=28781 |
Page 1 of 1 |
| Author: | MindMergepk [ June 4th, 2014, 11:44 ] |
| Post subject: | Seagate 500GB No Terminal Access |
Hi, There are already few threads on the same problem, but there was no solution or hint for these drive, anyway i will try with a new one. The drive is Seagate Desaru family; ST9500423AS FW: 0005DEM1 Spins up comes to ready state in pc3k but no terminal access, terminal output here; EarlySpinup Enabled Rst 0x10M ExecuteSpinRequest LED:00000067 FAddr:00380338 LED:00000067 FAddr:00380338 LED:00000067 FAddr:00380338 drive doesn't spin down after LED errors. Any hint !! highly appreciate your reply. |
| Author: | labtech [ June 4th, 2014, 13:39 ] |
| Post subject: | Re: Seagate 500GB No Terminal Access |
Is it a "for Dell or HP manufacturer" drive? Can tell from the P/N I think. |
| Author: | MindMergepk [ June 4th, 2014, 15:00 ] |
Not sure PART NO ON DRIVE IS: 9RT143-033 |
| Author: | labtech [ June 4th, 2014, 15:20 ] |
On the label itself, any dell or hp mentioning what-so-ever? |
| Author: | MindMergepk [ June 5th, 2014, 3:09 ] |
No, there is nothing on label like hp or dell |
| Author: | labtech [ June 5th, 2014, 6:29 ] |
Sorry, I overlooked/ommited a small detail. In the firmware, it does show it is for Dell. Either way, I was looking for something that does not apply in this situation. |
