| WD usb3 recovery!!!!!! http://forum.hddguru.com/viewtopic.php?f=11&t=28847 |
Page 1 of 1 |
| Author: | alimeci [ June 15th, 2014, 2:47 ] |
| Post subject: | WD usb3 recovery!!!!!! |
hi i have a hdd m password WD usb3 i doing slove slow...... i access to all sector (by terminal) all Modules ok heads ok pcb ok by cable usb3 no read sector now hdd detecting in windows and massege formating but i use all option recovery but no recovery Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 6 Cyl Count............................... : 256 Zone allocation table................... : Ok SA SPT.................................. : 1372 ROM: ROM reading............................. : Ok ROM Data size........................... : 256 Kb ROM version............................. : 65.04J ROM generation.......................... : 65.04J Link table version...................... : 05.0F. Consolidated ROM version................ : 00650004 ROM Modules: Flash ROM dir reading................... : Ok SA regions address...................... : by default SA Translator loading................... : Ok Heads configuration..................... : by map Heads number............................ : 6 Heads number in use..................... : 6 Switched off heads...................... : No Heads map............................... : 0,1,2,3,4,5 ROM Firmware version.................... : 00650004 Service area: Permanent overlay....................... : Loaded SA dir reading (ID)..................... : Ok SA Access............................... : Copy 0,Copy 1 Configuration reading................... : Ok Master Password......................... : has not been set User Password........................... : has not been set plz my help thank you |
| Author: | MindMergepk [ June 15th, 2014, 8:41 ] |
| Post subject: | Re: WD usb3 recovery!!!!!! |
did you try DE for imaging this drive ? have you tried changing head map ? |
| Author: | alimeci [ June 15th, 2014, 8:56 ] |
Drive in DE with USB cable sector in the wake of three black display However, terminals in green, but the speed is very very low An alternative method, and I donot know it. |
| Author: | MindMergepk [ June 15th, 2014, 10:41 ] |
alimeci wrote: Drive in DE with USB cable sector in the wake of three black display However, terminals in green, but the speed is very very low An alternative method, and I donot know it. sorry i did't really understand it, can you please explain it little more. If you can read sectors but speed is very very slow, than forget the alternate method. you should verify the reading from random position is it same at all places (means very very slow) try reverse imaging .. see if it helps |
| Author: | labtech [ June 15th, 2014, 15:25 ] |
Sounds like drive has a firmware issue, hence the slow behavior. It may have other issues as well, but the firmware is simple to check IF the drive allows you to (seems like it should). |
| Author: | northwind [ June 16th, 2014, 4:21 ] |
You need to convert to sata and work your way after that. |
| Author: | Madoka [ June 16th, 2014, 5:14 ] |
northwind wrote: You need to convert to sata and work your way after that. Good morning ! I do agree ! Either that or using a compatible SATA PCB ! Have a nice week. |
| Author: | alimeci [ June 16th, 2014, 18:12 ] |
Hello Friend I did drive to SATA Modules are correct. Heads are correct I read over the sector But I can not retrieve any information What should I do |
| Author: | alimeci [ June 16th, 2014, 19:21 ] |
hi what i doing for initialize the translator. thanks |
| Author: | alimeci [ June 16th, 2014, 20:07 ] |
Spildit wrote: alimeci wrote: hi what i doing for initialize the translator. thanks I guess that you can try smart hot swap or do head map in RAM if you have DE. sorry you can remot my system? by team viwer |
