Toshiba MK6022GAX with bad PCB
http://forum.hddguru.com/viewtopic.php?f=11&t=28957
Author:  pclab [ July 1st, 2014, 6:18 ]
Post subject:  Toshiba MK6022GAX with bad PCB
Hi
I have this HDD with bad PCB (can't spin the platters and it gets very hot).
I have a MK6021GAS as the most similar donor. I put PCB on pacient and it spins.
I have tried to read CP from pacient but it doesn't reach RDY (only PCB).
Can I use the PCB from MK6021GAS and swap chip?
The chip is the one with the F00xxx sticker on it, right?
Author:  data-medics [ July 1st, 2014, 15:51 ]
Post subject:  Re: Toshiba MK6022GAX with bad PCB
Hi PCLAB,
Manually load the utilility in PC-3000, might take a few min since it's not ready. Click on the terminal tab, press enter, power cycle the pcb and quickly press enter again, that should force it into a ready state. Then you can read the CP and reprogram the other board.
If you need help let me know, I can TV in and do it for you. Should only take a minute.
Author:  data-medics [ July 1st, 2014, 15:54 ]
Oh yeah, and make sure that you have the terminal connected. :D
Author:  pclab [ July 2nd, 2014, 5:21 ]
Hello Data-Medics
I have tried that already. Only with PCB connected, it get's BSY for a few minutes, then all the lights go on and can't do nothing..
Can't read CP...
Author:  SALIM [ August 5th, 2014, 18:40 ]
data-medics
sir
please reply here, for next step
Author:  data-medics [ August 5th, 2014, 18:42 ]
Are you talking to me?
Author:  SALIM [ August 9th, 2014, 19:53 ]
YES
as you said, we can build new pcb for toshiba, if original pcb is missed.
