ROM Required | WD7500KMVW-11ZSMS1
http://forum.hddguru.com/viewtopic.php?f=11&t=28971
Author:  MindMergepk [ July 2nd, 2014, 15:38 ]
Post subject:  ROM Required | WD7500KMVW-11ZSMS1
ROM Needed FOR THIS Helios Family;
WD7500KMVW-11ZSMS1
ROM VER : 00080007
Thanks in advance.
Author:  data-medics [ July 2nd, 2014, 15:44 ]
Post subject:  Re: ROM Required | WD7500KMVW-11ZSMS1
Closest I have is:
WD7500KMVW-11ZSMS4
ROM VER: 0008000F
If you want it.
Author:  Sasha Sheremetov [ July 2nd, 2014, 16:51 ]
Here it is.
ROM+mod11.zip [423.15 KiB]
Downloaded 496 times
WD10TMVW-11ZSMS1
>Heads configuration..................... : by map
>Heads number............................ : 6
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5
>ROM Firmware version.................... : 00080007
Compare ROM sizes on donor and patient before writting (use U12 chip datasheet if it's unreadable).
You will probably need to disable top head.
Author:  thatdellguy [ July 2nd, 2014, 17:25 ]
There is a compatible one in the hddguru files section.
Author:  MindMergepk [ July 10th, 2014, 15:55 ]
Sasha Sheremetov wrote:
Here it is.
ROM+mod11.zip
WD10TMVW-11ZSMS1
Thanks a lot
Sasha
the original head map was 0,1,2,3,5
