 Post subject: Trying to identify Samsung branded Seagate family
PostPosted: July 7th, 2014, 11:38
Hi all,
I've got a ST1000LM024 HN-M101MBB drive here and I'm having a hard time identifying the correct module to use in PC-3000. The drive correctly ID's, recognizes as "Seagate F3 Arch (Common)" family, and I even have sector access. But I'd really like to build a headmap and the common utility doesn't allow for that.
Does anyone know what family these are? I can't even seem to get terminal access, only scrambled data coming in when it first powers on.
Thanks for any help here.
 Post subject: Re: Trying to identify Samsung branded Seagate family
PostPosted: July 7th, 2014, 15:16
It's a Samsung technology drive, so use the Samsung utility.
The baud rate is different to Seagate F3 hence the garbage.
PostPosted: July 7th, 2014, 15:27
Yes like pcimage says this is Samsung drive. You need to use Samsung Utility and choose HN-M101MBB.
I have one on shelf.
After power on and select family in Utility go in terminal and you will see correct Samsung output.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: July 7th, 2014, 16:07
Pretty basic, look at the PCB. It's clearly Samsung. :lol:
PostPosted: July 7th, 2014, 17:08
Ok, thanks for the help. I guess I was just thrown off because it detects it as Seagate F3 Arch, and it does say Monumentus on the drive.
PostPosted: July 7th, 2014, 17:14
data-medics wrote:
... it does say Monumentus on the drive.
Look again.
PostPosted: July 7th, 2014, 19:57
I believe OP's drive may come from some branded PC or something similar, as these drives sold here just have
"Model: ST1000LM024
HDD P/N: HN-M101MBB"
printed directly on the sticker and a Samsung Spinpoint logo below.
PostPosted: July 8th, 2014, 10:12
It definitely says Momentus on the drive, and it also says Spinpoint.
I've had a couple drives in the past that were Samsung branded and actually were true Seagate. I guess I thought this was another one of those, but I guess it wasn't. I don't get many Samsung drive here, this is only about the 4th one.
PostPosted: July 8th, 2014, 14:36
Look again.
Monumentus, lol !
Users browsing this forum: Google [Bot] and 9 guests
cron
