| Trying to identify Samsung branded Seagate family http://forum.hddguru.com/viewtopic.php?f=11&t=29000 |
Page 1 of 1 |
| Author: | data-medics [ July 7th, 2014, 11:38 ] |
| Post subject: | Trying to identify Samsung branded Seagate family |
Hi all, I've got a ST1000LM024 HN-M101MBB drive here and I'm having a hard time identifying the correct module to use in PC-3000. The drive correctly ID's, recognizes as "Seagate F3 Arch (Common)" family, and I even have sector access. But I'd really like to build a headmap and the common utility doesn't allow for that. Does anyone know what family these are? I can't even seem to get terminal access, only scrambled data coming in when it first powers on. Thanks for any help here. |
| Author: | pcimage [ July 7th, 2014, 15:16 ] |
| Post subject: | Re: Trying to identify Samsung branded Seagate family |
It's a Samsung technology drive, so use the Samsung utility. The baud rate is different to Seagate F3 hence the garbage. |
| Author: | Kum Ruzvelt [ July 7th, 2014, 15:27 ] |
Yes like pcimage says this is Samsung drive. You need to use Samsung Utility and choose HN-M101MBB. I have one on shelf. After power on and select family in Utility go in terminal and you will see correct Samsung output. |
| Author: | thatdellguy [ July 7th, 2014, 16:07 ] |
Pretty basic, look at the PCB. It's clearly Samsung. |
| Author: | data-medics [ July 7th, 2014, 17:08 ] |
Ok, thanks for the help. I guess I was just thrown off because it detects it as Seagate F3 Arch, and it does say Monumentus on the drive. |
| Author: | fzabkar [ July 7th, 2014, 17:14 ] |
data-medics wrote: ... it does say Monumentus on the drive. Look again. |
| Author: | Dmitri [ July 7th, 2014, 19:57 ] |
data-medics wrote: it does say Monumentus on the drive. I believe OP's drive may come from some branded PC or something similar, as these drives sold here just have "Model: ST1000LM024 HDD P/N: HN-M101MBB" printed directly on the sticker and a Samsung Spinpoint logo below. |
| Author: | data-medics [ July 8th, 2014, 10:12 ] |
It definitely says Momentus on the drive, and it also says Spinpoint. I've had a couple drives in the past that were Samsung branded and actually were true Seagate. I guess I thought this was another one of those, but I guess it wasn't. I don't get many Samsung drive here, this is only about the 4th one. |
| Author: | Madoka [ July 8th, 2014, 14:36 ] |
fzabkar wrote: data-medics wrote: ... it does say Monumentus on the drive. Look again. Monumentus, lol ! |
