 Post subject: WD10JMVW-11S5XS0 - Firebird Family
PostPosted: July 8th, 2014, 19:05
Need Resources;
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 23.1UC
ROM generation.......................... : 23.1VC
Link table version...................... : TP.2E.
Consolidated ROM version................ : 0023001U
Thanks in advance.
Data Recovery Pakistan
 Post subject: Re: WD10JMVW-11S5XS0 - Firebird Family
PostPosted: July 9th, 2014, 3:39
Looked, but don't have, sorry.
PostPosted: July 9th, 2014, 10:25
What exactly is needed?
Mikippp
WD3200BMVW-11S5XS0
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 73 561
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 0023001U
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
File comment: ROM+11.rpm
ROM.zip [641.81 KiB]
Downloaded 550 times
PostPosted: July 13th, 2014, 14:15
case solved.
Users browsing this forum: No registered users and 38 guests
