 Post subject: PC3K bug
PostPosted: July 10th, 2014, 6:22
Hello guys,
I have the following error with PC3K UDMA : "S/N Reading error:I/N mumber read error. Read command sending error. HW CODE: FF"
It happened since last upgrade when I start up the software. I must say it already happened a few months ago and that the only solution I could find to make it work at the time was to reinstall the whole OS (Windows 7 32bits).
I asked Acelabs at the time for this error but I couldn't get any satisfying answer.
Now that it happens again, I wish I wouldn't have to lose all day to eventually make it work by reinstalling Windows over and over again.
For the moment, I uninstalled it and tried to reinstall it but the same message appears and break the installation process.
Has this ever happened to anybody ? Was any stable solution found out ?
Thanks a lot for your advice !
 Post subject: Re: PC3K bug
PostPosted: July 10th, 2014, 7:38
hm, are you sure your machine's HDD and RAM are ok?
PostPosted: July 10th, 2014, 13:03
HDD and RAM were tested ok.
Actually this time, I only had to reboot the computer. Installation then went properly so everything is now resolved for the moment.
In the meanwhile, I received an answer from Acelabs (Roman) 5 mns after this post was read by their team and only half an hour after I submitted a ticket. As I think it may be useful as a quick help in the future for any of us, here it is :
Please try to uninstall PC-3000 driver, and than - reboot your PC. After that you should launch PC-3000 setup and install new version of driver with software.
I hope it can help !
PostPosted: July 11th, 2014, 5:05
Nice!
