 Post subject: ST3500DM002 FW CC4C
PostPosted: July 9th, 2014, 6:22
I have a ST500DM002 hdd Sata, as hdd running smoothly but no access to terminal....
When I power on the hdd this below message appears......I have try to short pin points number of times but cannt access the terminal......
So how can we recover the data of the hdd.....
Boot 0x40M
Spin Up
TCC-002D[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-002D
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 001BAC05
[RSRS] 0765
ProcessRWError -Read- at LBA 000000000005FD3B Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005FD3D Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005FD3F Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000005FD3F!
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-002D
LED:00000047 FAddr:FFFFFFFE
 Post subject: Re: ST3500DM002 FW CC4C
PostPosted: September 17th, 2014, 0:05
很简单的一个问题,硬盘加电后在主固件复位后,mcmt加载前马上短接pcb上的前置放大器读通道,然后硬盘会进行一些错误提示,等待执行完毕后,就可以进入T,接下来就可以进行固件区坏道检测和修复了,然后清除V4,重置smart和30a和346sys,然后重新加断电,这时候一般可以正常认盘了,如果不行的话,继续清除V4,然后m0,2,2,,,,,22盘一般就好了。
PostPosted: September 17th, 2014, 2:01
better in english
PostPosted: September 18th, 2014, 8:14
@crystalrajasthan
If you need data recovery do not do what it says in chinese
PostPosted: September 18th, 2014, 22:27
Judging by the description, that's surface defects in the SA and probably in the other areas.
