 Post subject: ROM Required | WD7500KMVW-11ZSMS1
PostPosted: July 2nd, 2014, 15:38
ROM Needed FOR THIS Helios Family;
WD7500KMVW-11ZSMS1
ROM VER : 00080007
Thanks in advance.
Data Recovery Pakistan
 Post subject: Re: ROM Required | WD7500KMVW-11ZSMS1
PostPosted: July 2nd, 2014, 15:44
Closest I have is:
WD7500KMVW-11ZSMS4
ROM VER: 0008000F
If you want it.
PostPosted: July 2nd, 2014, 16:51
Here it is.
ROM+mod11.zip [423.15 KiB]
Downloaded 497 times
WD10TMVW-11ZSMS1
>Heads configuration..................... : by map
>Heads number............................ : 6
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5
>ROM Firmware version.................... : 00080007
Compare ROM sizes on donor and patient before writting (use U12 chip datasheet if it's unreadable).
You will probably need to disable top head.
VISUAL NAND RECONSTRUCTOR. Since 2014.
PostPosted: July 2nd, 2014, 17:25
There is a compatible one in the hddguru files section.
PostPosted: July 10th, 2014, 15:55
Sasha Sheremetov wrote:
Here it is.
ROM+mod11.zip
WD10TMVW-11ZSMS1
Thanks a lot
Sasha
the original head map was 0,1,2,3,5
