Hi, What exactly is needed?
Mikippp
WD3200BMVW-11S5XS0
>Techno mode key >Techno mode key......................... : Ok > >RAM: >HDD Info reading........................ : Ok >Heads number............................ : 2 >Cyl Count............................... : 256 > >Zone allocation table................... : Ok >SA SPT.................................. : 1437 > >ROM: >ROM reading............................. : Ok >ROM Data size........................... : 256 Kb >ROM version............................. : 23.1UC >ROM generation.......................... : 23.1VC >Link table version...................... : TP.2E. >Consolidated ROM version................ : 0023001U > >ROM Modules: >Flash ROM dir reading................... : Ok (Active) >Flash ROM dir reading (Ext)............. : Ok >Modules directory address............... : 73 561 >SA regions address...................... : by default >SA Translator loading................... : Ok > >Heads configuration..................... : by map >Heads number............................ : 2 >Heads number in use..................... : 2 >Switched off heads...................... : No >Heads map............................... : 0,1 >ROM Firmware version.................... : 0023001U > >Service area: >Permanent overlay....................... : Loaded >SA dir reading (ID)..................... : Ok >SA Access............................... : Copy 0,Copy 1
| Attachments: |
File comment: ROM+11.rpm
ROM.zip [641.81 KiB]
Downloaded 551 times
