| PC3K bug http://forum.hddguru.com/viewtopic.php?f=11&t=29025 |
Page 1 of 1 |
| Author: | m_K [ July 10th, 2014, 6:22 ] |
| Post subject: | PC3K bug |
Hello guys, I have the following error with PC3K UDMA : "S/N Reading error:I/N mumber read error. Read command sending error. HW CODE: FF" It happened since last upgrade when I start up the software. I must say it already happened a few months ago and that the only solution I could find to make it work at the time was to reinstall the whole OS (Windows 7 32bits). I asked Acelabs at the time for this error but I couldn't get any satisfying answer. Now that it happens again, I wish I wouldn't have to lose all day to eventually make it work by reinstalling Windows over and over again. For the moment, I uninstalled it and tried to reinstall it but the same message appears and break the installation process. Has this ever happened to anybody ? Was any stable solution found out ? Thanks a lot for your advice ! |
| Author: | northwind [ July 10th, 2014, 7:38 ] |
| Post subject: | Re: PC3K bug |
hm, are you sure your machine's HDD and RAM are ok? |
| Author: | m_K [ July 10th, 2014, 13:03 ] |
Quote: hm, are you sure your machine's HDD and RAM are ok? HDD and RAM were tested ok. Actually this time, I only had to reboot the computer. Installation then went properly so everything is now resolved for the moment. In the meanwhile, I received an answer from Acelabs (Roman) 5 mns after this post was read by their team and only half an hour after I submitted a ticket. As I think it may be useful as a quick help in the future for any of us, here it is : Quote: Please try to uninstall PC-3000 driver, and than - reboot your PC. After that you should launch PC-3000 setup and install new version of driver with software. I hope it can help ! |
| Author: | northwind [ July 11th, 2014, 5:05 ] |
m_K wrote: In the meanwhile, I received an answer from Acelabs (Roman) 5 mns after this post was read by their team and only half an hour after I submitted a ticket. Nice! |
