HDD GURU FORUMS
http://forum.hddguru.com/
Cannot access the terminal ST500DM002
http://forum.hddguru.com/viewtopic.php?f=11&t=29063
Page 1 of 1
Author:  crystalrajasthan [ July 16th, 2014, 4:44 ]
Post subject:  Cannot access the terminal ST500DM002
I have 2 Seagate Sata ST500DM002 hdd, both the hdd spins normal but cannot access the terminal. Even I try to short pin point also ....it shows the following message as show below after shorting :-
Boot 0x10M
Spin Up[0x00000000][0x00000000]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
FAIL Servo Op=0155 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x00025CB4][0x00025CB4]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
FAIL Servo Op=0055 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x0000B319][0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x00030FCD][0x00030FCD]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
Any help appreciated....
Author:  labtech [ July 16th, 2014, 8:50 ]
Post subject:  Re: Cannot access the terminal ST500DM002
See other thread of yours for reply
Author:  mohamad65 [ July 16th, 2014, 10:05 ]
just test by shot pin in pcb
http://www.phpbb.com/
