 Post subject: ST1000DM003 keeps BSY no Terminal access
PostPosted: August 12th, 2014, 17:57
Hello guys,
I need your help with a ST1000DM003
It's
PN: 9YN162-500
FW: CC4B
PCB: 100664987 REV B
Customer said: Didn't fell. Just stopped working from one day to the other.
Spindle motor works.
I tried the clients PCB on a similiar Drive with donors Firmware and the donors drive worked perfectly.
The other way around didn't work. (donors PCB is same number but REV A).
PC3000 shows only BSY. Never gets to readiness
Tried to make the "HDD Lock (LED: 000000CC)" Solution but it didnt work. Seems to have no access to the drive.
Tried the donors Head, but still keeps BSY.
In some forums I found people saying maybe firmware corrupted, but I dont know how to fix this.
Terminal shows:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-001F[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001F
RECOV Servo Op=0900 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 001565D7
[RSRS] 0430
ProcessRWError -Read- at LBA 00000000000362D0 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000362D0!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Reconstruction: EXCEPTION: Error in Header
Reconstruction: EXCEPTION: Error in first Header disc sector
ReadFooters (Backwards): Segment 0430 StartLBA 001B1680 Starting Footer LBA 001B1CB0
SeqNum 001565D8
ProcessRWError -Read- at LBA 0000000000036396 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036396!
Footer Status = 0000
ProcessRWError -Read- at LBA 000000000003638D Sense Code=40000087!
Starting LBA of RW Request=000000000003638D Length=00000009
ProcessRWError -Read- at LBA 000000000003638E Sense Code=43110081!
ProcessRWError -Read- at LBA 000000000003638F Sense Code=43110081
RECOV Servo Op=0065 Resp=0005!
ProcessRWError -Read- at LBA 0000000000036390 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036390!
ProcessRWError -Read- at LBA 0000000000036384 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036384!
ProcessRWError -Read- at LBA 000000000003637B Sense Code=40000087!
ProcessRWError -Read- at LBA 000000000003637E Sense Code=40000087!
Starting LBA of RW Request=000000000003637B Length=00000009
ProcessRWError -Read- at LBA 000000000003637F Sense Code=43110081!
ProcessRWError -Read- at LBA 0000000000036380 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036380!
Footer Status = 0001
ProcessRWError -Read- at LBA 000000000003636B Sense Code=40000087!
ProcessRWError -Read- at LBA 0000000000036360 Sense Code=40000087!
ProcessRWError -Read- at LBA 0000000000036361 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036361!
ProcessRWError -Read- at LBA 0000000000036357 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036357!
ProcessRWError -Read- at LBA 000000000003634E Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000003634E!
ProcessRWError -Read- at LBA 0000000000036345 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036345!
ProcessRWError -Read- at LBA 000000000003633C Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000003633C!
ProcessRWError -Read- at LBA 0000000000036333 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036333!
ProcessRWError -Read- at LBA 000000000003632A Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000003632A!
ProcessRWError -Read- at LBA 0000000000036321 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036321!
ProcessRWError -Read- at LBA 0000000000036318 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036318!
ProcessRWError -Read- at LBA 000000000003630F Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000003630F!
ProcessRWError -Read- at LBA 0000000000036306 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000036306!
ProcessRWError -Read- at LBA 00000000000362FD Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000362FD!
ProcessRWError -Read- at LBA 00000000000362F4 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000362F4!
ProcessRWError -Read- at LBA 00000000000362EB Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000362EB!
ProcessRWError -Read- at LBA 00000000000362E2 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000362E2!
ProcessRWError -Read- at LBA 00000000000362D9 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000362D9!
Reconstruction: EXCEPTION: Error in Header and ALL Footers.
Continuing after error
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
Rst 0x40M
Spin Up
TCC-0020
LED:00000047 FAddr:FFFFFFFE
Please help. Thank you very much in advance.
 Post subject: Re: ST1000DM003 keeps BSY no Terminal access
PostPosted: September 16th, 2014, 2:58
sorry for delay in rezponse
looks like fw problem, but maybe heads problem or media problem too
are you tryed to disable pending bug?
PostPosted: September 17th, 2014, 0:04
很简单的一个问题,硬盘加电后在主固件复位后,mcmt加载前马上短接pcb上的前置放大器读通道,然后硬盘会进行一些错误提示,等待执行完毕后,就可以进入T,接下来就可以进行固件区坏道检测和修复了,然后清除V4,重置smart和30a和346sys,然后重新加断电,这时候一般可以正常认盘了,如果不行的话,继续清除V4,然后m0,2,2,,,,,22盘一般就好了。
PostPosted: November 24th, 2014, 1:24
I had a similar problem and was able to fix it. The symptoms were that the drive would spin up and make some noise, but the SATA link wouldn't come up. Linux didn't recognize the drive saying "COMRESET failed (errno=-16)". This is what the drive printed on the serial console when I started out.
Boot 0x40M
Spin Up
TCC-0019[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
Spin Up
TCC-0019
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 01070EA6
[RSRS] 05A5
ProcessRWError -Read- at LBA 000000000004906B Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000004906B!
ReadFooters (Backwards): Segment 05A5 StartLBA 00248358 Starting Footer LBA 00248988
SeqNum 01070EA7
ProcessRWError -Read- at LBA 0000000000049131 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000049131!
ProcessRWError -Read- at LBA 0000000000049128 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000004912B Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000004912B!
<snip>
ProcessRWError -Read- at LBA 0000000000049074 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000049074!
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001A
<snip>
I then shortened the two test points that were pointed out in the OP and the one between those two test points.
The drive printed out what I copied below and magically started working again. I was able to recover all my data.
Boot 0x40M
Spin Up
TCC-0026[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
Spin Up
TCC-0026
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00000000
[RSRS] 0000
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 00000001
MCMainPOR: Feature Enabled...
Starting LBA of RW Request=0000000000087F07 Length=000001AC
ProcessRWError -Read- at LBA 0000000000087F07 Sense Code=43110081
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000089F6F!
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000089F73!
(DOS)STE OGHT: 0x0000000000000000 - 0x0000000000000000 - 0x000512EA - 0x00051308 Count 0068
(DOS)CMP Count 0068
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004C0BE - 0x0000000D - 0x0000001C Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004BF10 - 0x0000000C - 0x0000001B Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004BD62 - 0x0000000B - 0x0000001A Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004BBB4 - 0x0000000A - 0x00000019 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004BA06 - 0x00000009 - 0x00000018 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004B858 - 0x00000008 - 0x00000017 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004B6AA - 0x00000007 - 0x00000016 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004B4FC - 0x00000006 - 0x00000015 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004B34E - 0x00000005 - 0x00000014 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004B1A0 - 0x00000004 - 0x00000013 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000049009 - 0x000000000004AFF2 - 0x00000003 - 0x00000012 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x000000000014A927 - 0x000000000014D11C - 0x000002BE - 0x000002DC Count 0059
(DOS)CMP Count 0059
(DOS)STE OGHT: 0x00000000048905A0 - 0x0000000004893C59 - 0x00006B71 - 0x00006B8F Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x00000000048BD804 - 0x00000000048BD9D6 - 0x00006B71 - 0x00006B8F Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x0000000002BAE50A - 0x0000000002BB1614 - 0x00004893 - 0x000048B1 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x0000000000137F61 - 0x000000000013A756 - 0x000001D7 - 0x000001F5 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x0000000000148659 - 0x000000000014AE4E - 0x000002A3 - 0x000002C1 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x000000000308848D - 0x000000000308B597 - 0x00005055 - 0x00005073 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x0000000000090686 - 0x00000000000939FC - 0x000000CF - 0x000000ED Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x00000000001456A7 - 0x0000000000147E9C - 0x0000027E - 0x0000029C Count 004A
(DOS)CMP Count 004A
(DOS)STE OGHT: 0x0000000002BA8E07 - 0x0000000002BABF11 - 0x0000485C - 0x0000487A Count 0044
(DOS)CMP Count 0044
(DOS)STE OGHT: 0x000000000014BDC7 - 0x000000000014E5BC - 0x000002CE - 0x000002EC Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x0000000001F0121A - 0x0000000001F0424B - 0x0000346B - 0x00003489 Count 0046
(DOS)CMP Count 0046
(DOS)STE OGHT: 0x0000000001F0504A - 0x0000000001F0807B - 0x00003493 - 0x000034B1 Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x000000000279D9A0 - 0x00000000027A1305 - 0x00003B52 - 0x00003B70 Count 0054
(DOS)CMP Count 0054
(DOS)STE OGHT: 0x00000000027941CC - 0x0000000002797B31 - 0x00003B00 - 0x00003B1E Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x0000000002797B32 - 0x000000000279B497 - 0x00003B1F - 0x00003B3D Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x0000000002791910 - 0x0000000002795275 - 0x00003AEA - 0x00003B08 Count 0051
(DOS)CMP Count 0051
(DOS)STE OGHT: 0x00000000027932FC - 0x0000000002796C61 - 0x00003AF8 - 0x00003B16 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x0000000002790DF4 - 0x0000000002794759 - 0x00003AE4 - 0x00003B02 Count 007A
(DOS)CMP Count 007A
(DOS)STE OGHT: 0x0000000002792B94 - 0x00000000027964F9 - 0x00003AF4 - 0x00003B12 Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x000000000191786A - 0x000000000191A89B - 0x00002A76 - 0x00002A94 Count 005A
(DOS)CMP Count 005A
(DOS)STE OGHT: 0x0000000002796A88 - 0x000000000279A3ED - 0x00003B16 - 0x00003B34 Count 0051
(DOS)CMP Count 0051
(DOS)STE OGHT: 0x0000000002796320 - 0x0000000002799C85 - 0x00003B12 - 0x00003B30 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000026F8366 - 0x00000000026F99D9 - 0x00003AE8 - 0x00003B06 Count 004D
(DOS)CMP Count 004D
(DOS)STE OGHT: 0x00000000027A1894 - 0x00000000027A3C20 - 0x00003AE8 - 0x00003B06 Count 004D
(DOS)CMP Count 004D
(DOS)STE OGHT: 0x00000000027A7D9E - 0x00000000027AB79E - 0x00003B2A - 0x00003B48 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000001F0A75A - 0x0000000001F0C039 - 0x000034CB - 0x000034E9 Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x0000000001FDF356 - 0x0000000001FE0AA7 - 0x000034CB - 0x000034E9 Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x00000000027A34A5 - 0x00000000027A6EA5 - 0x00003B03 - 0x00003B21 Count 0046
(DOS)CMP Count 0046
(DOS)STE OGHT: 0x0000000002795276 - 0x0000000002798BDB - 0x00003B09 - 0x00003B27 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x0000000001891E57 - 0x00000000018957BC - 0x00002440 - 0x0000245E Count 004D
(DOS)CMP Count 004D
(DOS)STE OGHT: 0x0000000001CA9C29 - 0x0000000001CAD58E - 0x00002B67 - 0x00002B85 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x0000000001B87E80 - 0x0000000001B8B78D - 0x0000289B - 0x000028B9 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x00000000001565BF - 0x00000000001599D0 - 0x0000023B - 0x00000259 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x000000000014782B - 0x000000000014A020 - 0x00000298 - 0x000002B6 Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x0000000001ECDC53 - 0x0000000001ECE594 - 0x00002E7F - 0x00002E9D Count 0057
(DOS)CMP Count 0057
(DOS)STE OGHT: 0x0000000001F21A61 - 0x0000000001F24A84 - 0x00002E7F - 0x00002E9D Count 0057
(DOS)CMP Count 0057
(DOS)STE OGHT: 0x00000000018A83B1 - 0x00000000018ABD16 - 0x00002501 - 0x0000251F Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x00000000027A636C - 0x00000000027A9D6C - 0x00003B1C - 0x00003B3A Count 0054
(DOS)CMP Count 0054
(DOS)STE OGHT: 0x000000000018F529 - 0x0000000000192A51 - 0x00000251 - 0x0000026F Count 004C
(DOS)CMP Count 004C
(DOS)STE OGHT: 0x00000000026F7DC9 - 0x00000000026F99D9 - 0x00003AE5 - 0x00003B03 Count 004A
(DOS)CMP Count 004A
(DOS)STE OGHT: 0x00000000027A1894 - 0x00000000027A3683 - 0x00003AE5 - 0x00003B03 Count 004A
(DOS)CMP Count 004A
(DOS)STE OGHT: 0x000000000279E108 - 0x00000000027A1893 - 0x00003B56 - 0x00003B74 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000027F4D6A - 0x00000000027F4F43 - 0x00003B56 - 0x00003B74 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x000000000279BA26 - 0x000000000279F38B - 0x00003B41 - 0x00003B5F Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x000000000279D238 - 0x00000000027A0B9D - 0x00003B4E - 0x00003B6C Count 0054
(DOS)CMP Count 0054
(DOS)STE OGHT: 0x0000000001CB8489 - 0x0000000001CBBAC8 - 0x00002C43 - 0x00002C61 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000027A99AF - 0x00000000027AD3AF - 0x00003B39 - 0x00003B57 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x00000000027A3E00 - 0x00000000027A7800 - 0x00003B08 - 0x00003B26 Count 0049
(DOS)CMP Count 0049
(DOS)STE OGHT: 0x0000000000158C61 - 0x000000000015C072 - 0x00000252 - 0x00000270 Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x0000000001CA9E03 - 0x0000000001CAD768 - 0x00002B68 - 0x00002B86 Count 0069
(DOS) Refresh Start.
(DOS)CMP Count 0069
(DOS)STE OGHT: 0x0000000001CB9449 - 0x0000000001CBCA88 - 0x00002C4C - 0x00002C6A Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x0000000001CB9609 - 0x0000000001CBCC48 - 0x00002C4D - 0x00002C6B Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x000000000279C71C - 0x00000000027A0081 - 0x00003B48 - 0x00003B66 Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x00000000027998D2 - 0x000000000279D237 - 0x00003B2F - 0x00003B4D Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x00000000027A7443 - 0x00000000027AAE43 - 0x00003B25 - 0x00003B43 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x00000000027AAA86 - 0x00000000027AE486 - 0x00003B42 - 0x00003B60 Count 0043
(DOS)CMP Count 0043
(DOS)STE OGHT: 0x00000000027A97D0 - 0x00000000027AD1D0 - 0x00003B38 - 0x00003B56 Count 0043
(DOS)CMP Count 0043
(DOS)STE OGHT: 0x00000000027A1C52 - 0x00000000027A5652 - 0x00003AF6 - 0x00003B14 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x00000000026F961C - 0x00000000026F99D9 - 0x00003AF2 - 0x00003B10 Count 005E
(DOS)CMP Count 005E
(DOS)STE OGHT: 0x00000000027A1894 - 0x00000000027A4ED6 - 0x00003AF2 - 0x00003B10 Count 005E
(DOS)CMP Count 005E
(DOS)STE OGHT: 0x00000000026F907F - 0x00000000026F99D9 - 0x00003AEF - 0x00003B0D Count 004C
(DOS)CMP Count 004C
(DOS)STE OGHT: 0x00000000027A1894 - 0x00000000027A4939 - 0x00003AEF - 0x00003B0D Count 004C
(DOS)CMP Count 004C
(DOS)STE OGHT: 0x00000000026F8AE2 - 0x00000000026F99D9 - 0x00003AEC - 0x00003B0A Count 004B
(DOS)CMP Count 004B
(DOS)STE OGHT: 0x00000000027A1894 - 0x00000000027A439C - 0x00003AEC - 0x00003B0A Count 004B
(DOS)CMP Count 004B
(DOS)STE OGHT: 0x00000000026F8903 - 0x00000000026F99D9 - 0x00003AEB - 0x00003B09 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x00000000027A1894 - 0x00000000027A41BD - 0x00003AEB - 0x00003B09 Count 0045
(DOS)CMP Count 0045
(DOS)STE OGHT: 0x00000000027A6EA6 - 0x00000000027AA8A6 - 0x00003B22 - 0x00003B40 Count 0051
(DOS)CMP Count 0051
(DOS)STE OGHT: 0x00000000027A6AE8 - 0x00000000027AA4E8 - 0x00003B20 - 0x00003B3E Count 0043
(DOS)CMP Count 0043
(DOS)STE OGHT: 0x0000000001F21C3B - 0x0000000001F255A0 - 0x00002E85 - 0x00002EA3 Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x00000000011A9CD8 - 0x00000000011AD63D - 0x00001A14 - 0x00001A32 Count 0043
(DOS)CMP Count 0043
PowerState = IDLE1
APM disabled by SPort
HighPowerMode Status 0001 Req 0006
Dither
PowerState = IDLE1
PowerState = IDLE2
(H) SATA Reset
PostPosted: January 5th, 2015, 15:02
HI
How do I solve this problem to PC 3000 EXPERS?
PostPosted: January 5th, 2015, 15:14
I recommend ACE tech support - ts.acelaboratory.com. They will be back from holiday next week.
PostPosted: January 19th, 2015, 0:32
IT can be solved BY mrt
PostPosted: February 9th, 2015, 22:06
Drive comes up ready at first but then after any command hangs in BSY? or is is BSY right from the start.
Looking at the log your drive is showing it may have issues with relocating.
Go to Test - Work with SA - edit passport information
remove all the check marks in regards to relocation there, and repower the drive.
If your drive does not give ready signal at all right from the start. check to see if you can read FID_5_347
report back
