Page 1 of 1
Taskbar problems
Posted: August 25th, 2014, 9:04
by henerywatson
Generally many pc user are face taskbar problem and also we are like the new Windows 7 taskbar, but many people seem less than impressed with the new approach to taskbar buttons, finding it difficult to tell at a glance whether an icon is a running application or a pinned shortcut. If this sounds like you then there's an easy way to restore more standard taskbar buttons, though - right-click the taskbar, select Properties, and set Taskbar Buttons to "Never combine" or "Combine when taskbar is full". Before some days ago, I asked to tech support expert i.e. click4support then they provided me these solution...i.e ...
You can even restore the old Quick Launch toolbar in just a few clicks. Simply right-click the taskbar, click Toolbars > New Toolbar, type %userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch in the folder box and click Select Folder. The Quick Launch toolbar should then reappear, and you can move and resize it to suit your needs. I think, it's best option for all of us and If any other methods are available then suggest to me...
