Wd usb3 recovery!!
http://forum.hddguru.com/viewtopic.php?f=11&t=29413
Page 1 of 2
Author:  alimeci [ August 31st, 2014, 17:30 ]
Post subject:  Wd usb3 recovery!!
Hi
I have a USB drive follow-Western 500 usb3
Not identified
the terminal the Relo list i do and head and the heads of the testing was
And the translator regenetor would have chosen
No change was
Then I turned off SATA hard drive into the SATA mode to do things twice, but I did not change
What should I do.?
Author:  alimeci [ September 2nd, 2014, 11:37 ]
Post subject:  Re: Wd usb3 recovery!!
when i hot-swap the hdd to sata, the disk detected and give ID full OK.
all of madules read correctly.
I do complex test and there is a lot Bad-Sectors in end of disk, (from 900000000 to end is Bad-Sector).
hdd not shown in Disk managment in Windows 7 when to conect usb.
Author:  KYWD [ September 3rd, 2014, 3:42 ]
Hello alimeci,
First of all, I would like to ask you what types of test did you do to find that there were bad sectors on your disk?
You could try using the WD Data LifeGuard Diagnostics tool http://support.wdc.com/product/download ... =3&lang=en
Have you tried to connect the WD external drive with different SATA cable? Is your hard drive new?
In order to be able to help you on this issue I need little bit more of information.
Could you please, upload some printscreens?
Thank you.
KY_WD
Author:  northwind [ September 3rd, 2014, 4:12 ]
You need to image the drive (as SATA) and then decrypt it. Usually the key sector is at the end of the drive, so if this area is bad you may have a problem and need to fix it manually.
Author:  alimeci [ September 3rd, 2014, 10:57 ]
hi
thanks for post
how can i descrypt ?
Author:  alimeci [ September 4th, 2014, 6:23 ]
S.M.A.R.T.
Id : Name : Attribute : Threshold : Error : Worst : RAW
1 : Raw Read Error Rate : 200 : 51 : : 199 : 0
3 : Spin Up Time : 158 : 21 : : 155 : 3091
4 : Start/Stop Count : 100 : 0 : : 100 : 45
5 : Reallocated Sector Count : 200 : 140 : : 188 : 0
7 : Seek Error Rate : 200 : 0 : : 200 : 0
9 : Power-On Hours Count : 100 : 0 : : 100 : 29
10 : Spin Retry Count : 100 : 0 : : 253 : 0
11 : Recalibration Retries : 100 : 0 : : 253 : 0
12 : Device Power Cycle Count : 100 : 0 : : 100 : 42
192 : Power-Off Retract Count : 200 : 0 : : 200 : 33
193 : Load/Unload Cycle Count : 200 : 0 : : 200 : 143
194 : Temperature : 111 : 0 : : 100 : 36
196 : Reallocation Events Count : 200 : 0 : : 200 : 0
197 : Current Pending Sector Count : 200 : 0 : : 200 : 0
198 : Uncorrectable Sector Count : 100 : 0 : : 253 : 0
199 : UltraDMA CRC Error Rate : 200 : 0 : : 199 : 973
200 : Write Error Rate : 100 : 0 : : 253 : 0
S.M.A.R.T. Advanced Parameters
Parameter : Value
Off-line data collection status : 00 - Off-line data collection activity
: was never started.
Percent Self-Test Remaining : 0
Self-test execution status : 00 - The previous self-test routine
: completed without error or no self-test
: has ever been run
Total time in sec. to complete off-line : 13080
data collection :
EXECUTE OFF-LINE IMMEDIATE implemented : [x]
Abort/Restart off-line by host : [ ]
Off-line read scanning implemented : [x]
Short and Extended self-test implemented : [x]
Conveyance self-test implemented : [x]
Selective self-test implemented : [x]
Low Power mode save data : [x]
SMART Attribute Autosave Command Support : [x]
Self-test routine recommended polling : 2 min
time :
Extended self-test routine recommended : 130 min
polling time :
Conveyance self-test routine recommended : 5 min
polling time :
Self Test Log
Test Code : Test Status : Time (Hour) : Check Point : Failing LBA : Vendor Specific Data
00 : 00 : 0 : 0 : 0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Summary Error Log
Reg.Error : Sector Count : LBA : Reg.Status : State : Time (Hour) : Extended Error Info
00- : 0 : 0 : 00 : 00 : 0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Author:  alimeci [ September 4th, 2014, 6:24 ]
S.M.A.R.T.
Author:  alimeci [ September 4th, 2014, 7:03 ]
hi
my not know key?
and i no know how can use key?
Author:  KYWD [ September 4th, 2014, 9:20 ]
Hey alimeci,
Have you tried to see if the disk is shown in BIOS? Also, you can try your USB port to see whether it recognizes another USB devices.
You could find some support from the official WD website https://westerndigital.secure.force.com/ind/?lang=en.
Please, keep us posted what happened with the tests. Thank you.
KY_WD
Author:  fzabkar [ September 4th, 2014, 17:14 ]
alimeci wrote:
my not know key?
A backup copy of the key is sometimes stored in MOD 25. The actual key can be located by searching the user area at the end of the drive. For example, you could use a freeware disc editor (eg DMDE or HxD) to search the drive in reverse. If you upload a copy of MOD 25, then I may be able to help you. In fact I may soon have an Essentials drive for research purposes. Hopefully I will be able to come up with a DIY solution for those cases where the key has been corrupted or overwritten.
Author:  alimeci [ September 4th, 2014, 18:30 ]
hi all
very sorry
clone is end .
this is madule 25 and 38
madule25
0x0000 52 4F 59 4C 01 00 30 00 25 00 01 01 21 49 0D 2D ROYL..0.%...!I.-
0x0010 30 30 31 30 30 30 30 55 07 07 07 00 00 00 00 00 0010000U........
madule 38
0x0000 52 4F 59 4C 01 00 30 00 38 00 01 01 32 55 8A C9 ROYL..0.8...2UŠÉ
now what do i do?
Author:  fzabkar [ September 4th, 2014, 18:47 ]
The key sector(s) would be at offset 0x200 within the module.
BTW, I believe that PC3K has a software based solution for your case.
Author:  fzabkar [ September 4th, 2014, 20:18 ]
Here is an example of the key in MOD 25 from a WD30EZRX:
00000200  57 44 76 31 A5 E6 00 00 00 A0 4F 5D 01 00 00 00  WDv1¥æ... O]....
00000210  03 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00  ......ð.........
00000220  01 00 00 00 00 00 46 50 00 00 00 00 00 00 00 00  ......FP........
00000230  00 02 FF 00 00 00 00 00 00 00 00 00 00 00 00 00  ..ÿ.............
00000240  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000250  20 00 1D 8E 00 00 00 01 00 00 00 00 57 44 76 31   ..Ž........WDv1
00000260  B1 11 24 BB F2 06 B4 2B F5 5E 95 1A DF 84 8A 43  ±.$»ò.´+õ^•.ß„ŠC
00000270  62 A9 BB 9D AD 30 55 84 B8 72 2F A6 EE 55 83 AD  b©».­0U„¸r/¦îUƒ­
000003F0  EC 5C AA 59 69 C2 13 B6 CE 00 27 D6 E7 B5 C5 7A  ì\ªYiÂ.¶Î.'ÖçµÅz
Offset 0x208 (0x015D4Fa000) appears to define the size of the user area and the location of the SmartWare VCD. The key sector is located after the VCD.
BTW, if the drive is protected by a SmartWare password, then the key sector and its backup in MOD 25 will be modified accordingly. SmartWare also creates an additional sector where the password "hint" is stored.
Author:  alimeci [ September 5th, 2014, 3:12 ]
madule 25
0x0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0200 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0210 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0220 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0230 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x02C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x02D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x02E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x02F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0320 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0330 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
all lins is zero !!!
and this h.d.d no password
i clone from h.d.d usb 3 wd to a h.d.d 3.5inch Wd
now no recovery
i think The problem is SA in h.d.d usb
Author:  fzabkar [ September 5th, 2014, 3:25 ]
How do you know that your drive is affected by encryption? You didn't tell us the model (eg Essentials or Elements or something else).
Which bridge chip is the drive using? If it's a Symwave, then perhaps it is using a different module to backup the key sector. In fact I believe that the key sector will begin with "WMYS" (= "SYMW" in little-endian) rather than "WDv1".
Why don't you upload your drive's resources?
Author:  alimeci [ September 5th, 2014, 4:00 ]
model= my password
bridge chip=Symwave
and i not know upload your drive's resources!!
plz how upload resources?
Author:  northwind [ September 5th, 2014, 5:29 ]
The key for symwave is in 38, not 25.
Author:  alimeci [ September 5th, 2014, 5:55 ]
mdule 38 is such this madule 25
all line is zero
Author:  michael chiklis [ September 5th, 2014, 7:29 ]
an example of mod 38 from Sadle G6 WD20EARS-00MVWB0-51.0AB51 drive encrypted with symwave
38.rar [408 Bytes]
Downloaded 1003 times
Author:  alimeci [ September 5th, 2014, 9:06 ]
now what do i do by madule 38?
Page 1 of 2 All times are UTC - 5 hours [ DST ]
