 Post subject: LDR needed for WD40EFRX-68WT0N0
PostPosted: September 4th, 2014, 13:36
Hi all,
I need a loader for WD40EFRX-68WT0N0
ROM Version 00000032
I think it's Diablo3S family, but I'm not quite sure.
Thanks in advance!
 Post subject: Re: LDR needed for WD40EFRX-68WT0N0
PostPosted: September 4th, 2014, 16:25
Pm sent
Récupération de Données
PostPosted: September 5th, 2014, 8:25
ROM + ATA Ovl.
mikippp
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 8
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 2116
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 512 Kb
>ROM version............................. : 00.32C
>ROM generation.......................... : 00.33C
>Link table version...................... : 02.49.
>Consolidated ROM version................ : 00000032
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 402 902
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 8
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5,6,7
>ROM Firmware version.................... : 00000032
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
>Configuration reading................... : Ok
ROM_0032C_0249_WD40EZRX-00SPEB0.zip [701.65 KiB]
Downloaded 675 times
PostPosted: September 15th, 2014, 10:09
Does anyone know for sure what family this is? I checked module C5 and it looks to me like it says "SHOWA" as the family, but I could be wrong.
PostPosted: September 15th, 2014, 10:43
Actually I think it's a new family called GIANT
PostPosted: September 15th, 2014, 11:02
New WD red drives.
PostPosted: September 15th, 2014, 14:13
"SHOWA" refers to the manufacturer of the media, namely Showa Denko.
http://www.alexsoft.org/viewtopic.php?f=78&t=198
PostPosted: July 25th, 2015, 11:46
Fzabkar ,
This Post Was Good Thank You .Jared Its The Giant Family .Today i Have a WD40EFRX-68WT0N0 And i Would Be Posting About Its Issue Soon .Was Just Lill Busy Playing Around With My New DFL SRP - All In One .
