 Post subject: pcb compatible?
PostPosted: September 28th, 2014, 12:14
HI GUrus,
is PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0(This is faulty PCB)
& PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 COMPATIBLE ?
Can i use PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 as donor for PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0 as donor?
Thanks in advance
attachments.zip [8.92 MiB]
Downloaded 4595 times
 Post subject: WD5000AZRX / WD30EZRX pcb compatible?
PostPosted: September 30th, 2014, 13:59
Yes, if MCU tagging, PCB tagging and PCB revision are the same.
